ᐅ Why do some Malm drawers suddenly start sticking?
Created on: 12 Mar 2020 08:43
leo_bla
I recently noticed that some of my Ikea Malm dresser drawers have started to stick or have become harder to open than before. This issue seems to occur without any obvious external cause – no overloading, increased moisture, or visible dirt.
I am particularly interested in understanding the possible reasons why these drawers suddenly begin to stick. Has anyone had similar experiences or knows whether this relates to material quality, design, or perhaps the effects of regular use? Are there common weak points in the Malm drawers that could lead to sticking?
I would really appreciate a well-informed discussion or tips on the mechanisms behind this and how to potentially fix the problem permanently without having to replace the entire drawer.
CORYGAU
12 Mar 2020 11:46
leo_bla schrieb:
What do you guys think about using WD-40 for lubrication?
That’s a common misconception. WD-40 is primarily a water displacer, not a long-term lubricant. In fact, it can negatively affect plastics or painted surfaces because it leaves residues that attract dust and could cause the mechanism to stick even more.
If you want to lubricate, silicone-based lubricants or special gliding agents for furniture slides are more suitable.
Also, I think it’s important not just to focus on the lubricant itself but also on the causes behind changes in movement behavior. For example, material stress, slightly warped components, or even manufacturing tolerances.
DUUS32 schrieb:
Material fatigue, especially with temperature fluctuations or humidity, can cause wood warping.
That’s quite possible. Wood naturally expands and contracts, and combined with tight-fitting drawers, this can lead to sticking.
BeAndrea
12 Mar 2020 12:15
Hello leo_bla,
I’d like to add from my experience: Malm drawers often have small plastic or rubber stoppers on the sides that prevent the drawer from folding in. If these stoppers are misaligned or damaged, it can also cause the drawer to get stuck.
The sliding rails themselves are not particularly robust either – with frequent use, the rollers can shift or even tear.
A tip: Remove the drawer and check the stoppers and rollers for damage. Sometimes it also helps to clean the sliding rails from the inside with a brush, as dust and debris tend to accumulate there.
leo_bla schrieb:
Was haltet ihr eigentlich von WD-40 zum Schmieren?
I prefer graphite powder or silicone-based spray. WD-40 dries quickly and does not provide long-lasting lubrication.
DUUS32
12 Mar 2020 12:48
BeAndrea schrieb:
The Malm drawers often have small plastic or rubber stops on the sides that prevent the drawer from folding in.
That’s a good point I had overlooked.
In my case, one of these stoppers had indeed shifted slightly, which caused the drawer to get stuck at a specific point.
So it might be worth taking a close look at these small parts, as a misalignment here can be quite disruptive even though nothing visible is apparent.
Grace
12 Mar 2020 13:13
In addition to everything mentioned so far, I would like to address the importance of installation accuracy.
Drawers often stick because the furniture is slightly uneven or the floor is not perfectly level. When this happens, the drawers change their angle slightly when opened, which can cause them to jam.
A simple and quick solution is to adjust the drawers and dresser so they are no longer perfectly level – small furniture sliders under one corner or felt pads can help.
Also, it’s important to keep in mind that Malm drawers, despite their good appearance, are still budget furniture. This affects the materials used. With heavy use or over several years, problems can sometimes occur, even if the furniture is handled carefully.
I hope these tips are helpful to you, leo_bla.
besau
12 Mar 2020 13:54
Also check if the drawers are fully inserted straight. If the frame of the dresser is crooked, the drawer often gets stuck at the top edge.
leo_bla
13 Mar 2020 07:30
Thank you very much for the numerous and diverse suggestions! I have since removed the drawer, cleaned it, and also checked the runners and stoppers. One of the plastic stoppers was slightly shifted, which could definitely have been a cause.
Additionally, I slightly adjusted the Malm unit because the floor here is not completely level. After a minor adjustment and lubricating with a silicone-based spray, it now runs noticeably smoother.
I will continue to monitor the situation, but your contributions have really helped me approach the problem systematically. Especially Grace’s comment about the floor level was an aspect I hadn’t fully considered.
I’ll update here if the problem recurs or if further questions arise – but for now, I’m very satisfied!
Thanks and best regards!
