ᐅ How can Malm furniture be made more durable?
Created on: 23 Apr 2019 08:37
BIRGITT
BIRGITT
23 Apr 2019 08:37
I am currently looking into ways to make IKEA Malm furniture more durable, as I use several pieces daily that can be quite delicate. I am particularly interested in practical solutions that can be implemented easily without much effort.
I am thinking about methods to protect the surface, as well as reinforcements to keep the drawers or carcasses more stable. Maybe there are special maintenance products or tips regarding the right screws or installation techniques.
Does anyone here have experience or advice on how to make Malm furniture more robust over time without compromising its appearance or requiring too much effort?
I look forward to your input!
RON57
23 Apr 2019 09:15
Hello Birgitt,
your question is very well formulated and also very practical. Malm furniture is known for its simple design, but unfortunately also for its sensitivity, especially regarding the drawers and surfaces.
A proven tip is to treat the surfaces with a matte furniture wax, which protects against scratches and makes the surface more resistant to moisture. At the same time, the drawer slides can be maintained regularly with some silicone oil to keep them running smoothly.
Reinforcing the cabinet corners with small angle brackets or metal braces on the inside also provides more stability without being visually noticeable. It is also important to tighten the screws regularly to prevent any wobbling.
What have you done so far?
Chendu
23 Apr 2019 09:23
I would be interested to know if you have ever considered sealing the surfaces with clear varnish. This makes Malm furniture significantly more scratch-resistant. Otherwise, felt pads under the legs help to prevent wear on the floor.
PLOMA
23 Apr 2019 11:04
Hello Birgitt,
I would like to dive a bit deeper into the topic, as “making more durable” can mean many things, from mechanical strength to surface resistance.
1. Surface treatment: Malm furniture often has a foil coating that is unfortunately prone to scratches and scuffs. Completely sanding it down and repainting is possible but very labor-intensive and significantly changes the furniture’s appearance.
2. Protective film: An alternative is to apply a thin layer of polyurethane clear coat after thorough cleaning, which seals the surface. It is important to choose a varnish that cures with flexibility to avoid unsightly cracks.
3. Mechanical reinforcements: The joints in Malm furniture usually use Minifix dowels. Additionally, small metal brackets can be installed inside, especially at the corners where loads act. These brackets should be fixed with screws made of galvanized steel to prevent rust.
4. Drawers: These are the most delicate parts. They can be reinforced by building small guides from wooden slats or, if the original slides have play, by installing new ones with high-quality ball bearings.
5. Basics: Regularly tightening screws and avoiding overloading is essential.
I’m curious: What are your main use areas? Are the furniture pieces mainly for the bedroom, office, or living room? Depending on the environment, I can recommend more targeted measures.
Looking forward to your reply!
BIRGITT
23 Apr 2019 11:46
Thanks first of all for the quick responses and detailed tips, especially to RON57 and PLOMA!
Regarding your questions, PLOMA: The furniture is mainly in the bedroom and partly in the home office. The daily load varies—mainly clothes and smaller items are stored in the bedroom, while the home office sometimes holds heavier books. That is also why I am interested in the stability itself, not just the appearance.
So far, I have only tried some furniture oil on the surface, but it didn’t have much effect on the foil coating. Scratches and small dents become visible quickly.
The idea of using paint sounds interesting, but I am a bit concerned that the appearance might change or that the paint may not adhere well.
Has anyone had experience with primer or undercoat on these types of furniture foil finishes? Or RON57 – you mentioned waxes, could you possibly recommend a brand or product?
RON57
23 Apr 2019 12:21
Hello Birgitt,
Regarding wax: I like to use "Osmo furniture wax" or the "beeswax product from Clou." These products are easy to apply, provide a subtle protective layer, and leave the surface pleasantly matte, not glossy.
As for varnish: It can be quite tricky to get good adhesion on foil surfaces. A light sanding with fine-grit sandpaper (e.g., 220 grit) helps, followed by the use of a primer. However, this can noticeably affect the appearance.
If you only want protection, I would really recommend the furniture wax. It is less durable than varnish but flexible and can be reapplied as needed.
For retightening screws, I also suggest checking all connections every 2-3 months with a small Phillips or Allen screwdriver. This kind of maintenance can greatly contribute to stability and longevity.
I hope this helps!
