ᐅ How can IKEA PLATSA cabinet doors be replaced or swapped out?
Created on: 6 Dec 2018 08:37
Remzi30
Remzi30
6 Dec 2018 08:37
Hello everyone, I have an IKEA Platsa wardrobe and would like to replace or exchange the existing doors because they are a bit worn, and I’d like a fresh design. I’m especially interested in how to remove the doors effectively and without too much effort, whether replacement parts are available from IKEA, and if there might be any compatibility issues when installing newer doors in place of the old ones. Are there any particular tips or pitfalls I should watch out for? Maybe someone has practical experience or can provide details about the construction and installation of the doors. Thanks in advance for your help!
V
vinicius44
6 Dec 2018 10:22
Regarding the question of how to replace or exchange IKEA PLATSA cabinet doors, I would like to share some practical tips. First, it is important to know that the doors on PLATSA use concealed hinges, which can be unlocked relatively easily. Common IKEA doors usually detach from the cabinet frame by quickly pressing or releasing a plastic tab on the hinge. Replacement parts for doors and hinges are generally available directly from IKEA, but you should make sure to know the exact model number or color name of the doors, as there can be design changes between different production years or series that may cause compatibility issues. If the doors are no longer original or have been modified, it is advisable to check beforehand whether the new doors will actually fit. Finally, I recommend having a second person assist during installation, as doors are easier to align and fit when they can be held in place. This approach saves a lot of frustration.
GEKAU51
7 Dec 2018 14:56
vinicius44 schrieb:
Spare parts for doors and hinges are usually available directly from IKEA, but you should make sure to know the exact model number or color designation of the doors.
To be honest, I find IKEA’s approach a bit questionable. Sure, spare parts are available—at least officially—but neither stock levels nor availability are always reliable. Sometimes it feels like these "spare parts" exist more as a token gesture to maintain an appearance of sustainability, while you are ultimately forced to buy entire furniture parts again. Also, it bothers me that IKEA often changes the door designs for PLATSA without indicating that older cabinets then suddenly become incompatible. This causes unnecessary problems that could be avoided. So my recommendation: definitely speak with customer service before purchasing and, if necessary, consider alternative solutions, possibly third-party suppliers.
Nils58
8 Dec 2018 09:44
Remzi30 schrieb:
I am mainly interested in how the doors can be removed effectively and without too much effort
Hello Remzi30, great that you’re taking on this project! I recently modified my PLATSA wardrobe and can confirm that the doors are very easy to handle once you know the right technique. The hinges have a small plastic clip that you simply press or fold back, then the door detaches easily from the frame. It’s important to always lift the doors slightly while doing this to avoid any binding.
vinicius44 schrieb:
Finally, I recommend having a second helper on hand during installation
I can also recommend that, especially with larger doors! Additionally, I would suggest only fully screwing in the new door once you have checked its alignment—otherwise, it might sit crooked or not close properly. With some patience and fine adjustment, I achieved a really nice result and enjoy my new look every day! So don’t hesitate, it’s definitely worth it!
