ᐅ How can you retrofit Ikea Pax doors with soft-close mechanisms?
Created on: 27 Feb 2020 10:17
Digemeo
Digemeo
27 Feb 2020 10:17
I recently purchased an Ikea PAX wardrobe and am now considering how to retrofit the doors with a soft-close system. Although Ikea offers some doors with integrated soft-close features, they either don’t fit my setup or are too expensive for my current project.
My specific question is: What options are available for retrofitting a reliable and durable soft-close system on existing PAX doors, whether they are glass sliding doors or standard hinged doors? Are there special soft-close fittings or retrofit kits that work well with the Ikea PAX? And what should be taken into account regarding installation, space requirements inside the wardrobe, or compatibility with different types of doors?
I look forward to your experiences, recommendations, and any tips to ensure the retrofit goes smoothly.
LAURE-TA
27 Feb 2020 11:03
Hello Digemeo,
First, a few pieces of information upfront: Ikea PAX fronts can indeed be retrofitted with a soft-close feature, but it is important to choose the right type of fitting.
- For hinged doors, there are so-called "detachable hinges" with a soft-close function, available from Ikea or third-party suppliers. These are installed in place of the original hinges.
- Alternatively, hydraulic dampers can be attached inside the cabinet carcass to soften the closing of the doors.
- For glass sliding doors, it is more complicated, as they often require special soft-close tracks; be sure to measure the existing rail size carefully.
Things to watch out for:
- The hinges need to be appropriate for the door thickness and weight.
- During installation, it is important to precisely adjust the new hinges to ensure the doors close properly and no tension occurs.
- Sometimes it is necessary to modify or drill new holes when retrofitting.
My advice: If the budget allows, complete soft-close hinges from the manufacturer or a reputable accessory supplier tend to be the most durable and easiest to install. Hydraulic dampers are more of a last resort since they experience greater mechanical stress.
I hope this helps you get started.
Jamalli
27 Feb 2020 14:29
LAURE-TA schrieb:
If the budget allows, complete soft-close hinges from the manufacturer or a reputable accessory supplier are the most durable
May I briefly disagree? It is true that original parts often fit better, but they are usually much more expensive—and sometimes not even fully compatible.
I would recommend carefully measuring the hinge mounting points on both the door and the cabinet before purchasing. Many suppliers use different hole spacings and dimensions, which can make returns or modifications necessary.
Additionally, the discussion often overlooks that especially with Ikea PAX, the door series and generations vary. Some are built more sturdily, others are lighter, which affects the hinge weight and thus the durability of soft-close systems.
Another point: not all soft-close systems are the same. There are systems with gentle damping and others that close more abruptly. For some users, the feel when closing is more important than the technology itself.
In the end, it should also be noted that retrofitting soft-close often means the door becomes slightly heavier and may open differently. So the intended use should be taken into account.
My conclusion: just because it is "original" doesn’t automatically mean it is the best solution. Measuring, trying out, and comparing several manufacturers is, in my opinion, the best approach.
chen67
27 Feb 2020 16:48
Jamalli schrieb:
Many suppliers use different hole spacing and dimensions, which can require exchanges or reworking.
I agree with that! If you want to be sure, it’s best to grab a screwdriver and check the measurements yourself.
I recently fitted my PAX doors with an affordable soft-close kit that’s generally marketed for cabinet doors. It worked perfectly – no drilling needed because it just hooks on. It was a straightforward solution, and now the closing feels much more high-quality.
A small tip for anyone hesitating: maybe test it on one door first to see how the system performs on your model before upgrading the entire wardrobe.
Soft-close really brings a certain calm to the room, when doors don’t slam shut so loudly. Almost like meditation for the ears!
LAURE-TA
28 Feb 2020 09:22
chen67 schrieb:
Maybe test it on one door first and see how the system performs on your model before retrofitting the entire cabinet.
That is a very good suggestion.
Additionally, I would like to provide a brief guide in case someone wants to install a soft-close hinge insert themselves:
- Step 1: Remove the door and take out the hinges.
- Step 2: Obtain the original hinges with the soft-close insert and check for compatibility.
- Step 3: Attach the new hinges to the door, making sure the metal hinges are mounted cleanly and securely.
- Step 4: Rehang the door on the carcass.
- Step 5: Adjust the hinges by loosening and tightening the screws until the door closes smoothly and quietly.
Common mistakes include:
- Screws not being deep enough or being overtightened, which affects the functionality.
- Improper installation causing the door to hang unevenly or not close properly.
If you don’t want to do it yourself, a professional tradesperson can complete the job quickly. However, with some patience, this can be done successfully by yourself.
