I am currently exploring how to update the color of IKEA Hemnes furniture without completely losing its typical wood appearance or requiring extensive DIY skills. The Hemnes series is known for its classic shapes and rather rustic, light wood, which many people like but which doesn’t suit every interior style.
My main question is:
How can IKEA Hemnes furniture be refinished to achieve a fresh, modern look while keeping the piece sturdy and avoiding complex renovations or special painting techniques? Are there practical methods, such as specific paints, stains, or overpainting techniques, that work particularly well?
I look forward to your experiences and tips, including any advice on common pitfalls or recommended materials.
Thank you in advance!
PeoDaniel24 Feb 2024 10:39Hello Isidro,
I completely understand your question, as Hemnes furniture is really popular but often has a somewhat outdated look that many want to change.
Regarding repainting, I often recommend the following approach:
- First, sand the furniture thoroughly to roughen the surface, helping the paint adhere better.
- Then use a wood-based primer that seals the substrate and improves adhesion.
- For a durable and robust finish, acrylic paints or chalk paints work well and should be sealed with a protective clear coat (matte or glossy, depending on your preference).
Many people think you need perfect painting skills, but with good brushes or foam rollers, it works quite well if you apply thin layers.
Important: Before painting, try to disassemble the furniture as much as possible to reach corners better and achieve a more even final result.
If you want to change the color of Hemnes without completely covering the wood grain, I recommend special stains or transparent glazes that let the wood show through while altering the tone.
If you are interested in specific products, I can gladly share some brands I have personally used.
I hope this gives you a good starting point!
PeoDaniel schrieb:
If you want to change the color of Hemnes furniture without completely covering the wood grain, I recommend special stains or transparent glazes that allow the wood to show through while altering the tone.I agree with this and would like to add:
For Hemnes furniture, it is beneficial to use products specifically designed for pine wood, as Hemnes material is often made of solid pine. Using a stain that is too strong or a heavy varnish can damage or cause the surface to swell.
It is advisable to test the product on an inconspicuous spot before applying it to the entire piece.
In addition to traditional acrylic paints, water-based chalk paints can also be used safely, as they dry quickly and emit fewer chemical fumes.
It is also important to carry out all steps in a dry, dust-free environment and at moderate temperatures to achieve the best result.
There are also durable furniture adhesive films (e.g., films with wood or stone patterns) that allow a quick visual update if the DIY effort seems too large.
All in all, sanding, priming, and finishing with paint seem to me the best compromise between effort and durability.
Hello Isidro,
I would like to provide a practical guide on how to repaint Hemnes furniture. Here is a step-by-step instruction:
1. Cleaning: First, remove dust and grease using a mild detergent, such as dish soap, to ensure proper paint adhesion.
2. Sanding: Lightly sand all surfaces with sandpaper (grit 120-180). Be careful not to sand too much, as this can remove the wood grain texture.
3. Remove dust: After sanding, thoroughly remove all sanding dust, for example with a damp cloth.
4. Primer: Apply a primer suitable for wood and the paint you will use later. This prevents the wood from swelling and improves adhesion.
5. Apply paint: For Hemnes wooden furniture, water-based acrylic or chalk paint is best. Both provide good coverage and a nice matte or satin finish.
6. Sealing: To make the surface durable, finish with a clear topcoat, such as acrylic or polyurethane varnish.
Common mistakes:
- Insufficient sanding before painting = poor adhesion
- Painting on wet wood or in cold environments = paint problems
- Applying paint layers that are too thick
You can also consider painting individual parts (e.g., door fronts) in different colors or adding accents with stencils and patterns. This creates a modern look with little effort.
I hope this guide helps you.
Common mistakes:
LOGEMIN schrieb:
Additionally, you might consider painting certain parts (e.g., door fronts) in different colors or adding accents with stencils and patterns.Great tip! This instantly gives your Hemnes furniture more personality and a unique look!
For example, I painted the doors of my Hemnes wardrobe in a dark teal and left the insides light – it looks fantastic and modernizes the overall appearance with little effort.
And don’t worry about painting – just take it step by step and enjoy the process! 💪
You can achieve really great results even without professional experience. Maybe someone from the forum could share more of their color ideas or palettes? That would definitely be inspiring!
