ᐅ How can IKEA Hemnes furniture be protected from heat and sunlight?
Created on: 6 Dec 2016 08:42
eldarHello everyone,
I have several IKEA Hemnes furniture pieces in my apartment that unfortunately receive a lot of sunlight, especially in the mornings and afternoons. Since these pieces are made of solid pine wood, I am concerned about heat and direct sun exposure, particularly regarding potential discoloration, cracking, or drying out of the wood.
My question is: How can IKEA Hemnes furniture be effectively protected from heat and intense sunlight without negatively affecting the surface or appearance?
I am looking for advice on treatment options, suitable protective methods such as stains or oils, as well as tips on home remedies that might do more harm than good. Are there any recommendations for ideal placement or additional protective products?
Looking forward to your experiences and suggestions!
eldar schrieb:
My question is: How can IKEA Hemnes furniture be effectively protected from heat and intense sunlight without negatively affecting the surface or appearance?The most effective way is to prevent strong direct sunlight using UV-blocking curtains or blinds. Additionally, you can treat the furniture with clear wood oil or wax, which preserves the wood and prevents it from drying out.
eldar schrieb:
How can IKEA Hemnes furniture be effectively protected from heat and intense sunlight without negatively affecting the surface or appearance?I can recommend a thorough approach to best protect Hemnes furniture from sun and heat:
- First of all, it is clear that pine wood is relatively open-pored and absorbs moisture as well as dryness quite easily. It can expand and contract, which, under heat and strong UV light, can lead to small cracks or discoloration.
- To prevent this, I suggest gently sanding the wood surface with fine sandpaper (grit 240) so that it becomes more receptive to treatment.
- Then, using a high-quality, clear wood oil that includes UV protection is advisable. This protects the wood fibers from drying out and keeps the surface texture supple.
- Both linseed oil and special furniture oils that combine, for example, linseed oil with UV blockers or wax additives are recommended. It is important to reapply the treatment regularly (at least 1-2 times per year).
- Another tip concerns the placement of the furniture: if possible, position the Hemnes furniture where it is not exposed to direct strong afternoon sunlight all day. Also, room shading with curtains, window sun protection films, or blinds can make a significant difference.
- Be cautious with methods like varnishing or applying clear lacquer – while they do offer protection, they significantly change the surface and prevent the wood from breathing.
- Avoid home remedies such as vinegar-water solutions or overly aggressive cleaners since they dry out the wood and can cause discoloration.
Have you noticed if the furniture already shows minor damage or discoloration? In that case, it is important to prepare the surface accordingly, possibly with fine sanding and re-oiling.
I’m curious if your furniture is located in a particularly exposed spot; that way, more specific advice can be given.
fidasi schrieb:
First of all, it is clear that pine wood is relatively porous and absorbs moisture as well as dryness quite easily. It can expand and contract, which may cause small cracks or discoloration when exposed to heat and strong UV light.You described that very well! I’ve had similar furniture exposed to a lot of sun as well – the heat really made me anxious because the wood seemed to dry out gradually.
fidasi schrieb:
Also, room dimming through curtains, window films for sun protection, or blinds can make a big difference.I can definitely confirm that, since I installed new light-filtering curtains just last year. Since then, the wood looks much healthier. It’s probably also a combination of less direct sunlight and occasional treatment with wood oil.
However, one should not forget that these solid wood pieces develop a natural patina over time – which gives them character. For me, it’s important that no damage occurs that cannot be reversed. I wish IKEA provided more specific care instructions for this.
Does anyone else have experience with special products that can be safely applied to Hemnes? I suspect some oils are too greasy and might cause the surface to become blotchy.
