ᐅ How can Ikea Hemnes furniture be customized?
Created on: 22 Feb 2021 08:47
gepeo55
gepeo55
22 Feb 2021 08:47
Hello everyone, I am currently exploring how to customize Ikea Hemnes furniture in a distinctive and effective way without losing the original functionality and classic design. I am particularly interested in which materials, colors, or techniques are suitable for not only enhancing the appearance of Hemnes furniture but also personalizing it in a unique way. Additionally, it would be helpful if experiences with special paint finishes, handles, or the installation of additional features such as interior lighting or custom fittings could be shared. What creative and practical options do you know for personalizing Hemnes furniture, and what should be considered during the process? Thank you in advance for your knowledgeable tips and suggestions!
tra_nina
22 Feb 2021 10:23
There are several ways to customize Ikea Hemnes furniture. I generally recommend first considering the desired final look and the functional requirements. The existing surface of Hemnes furniture is usually painted, which allows for sanding and repainting with special chalk or furniture paints. The following points are important:
- Sand the surface with fine-grit sandpaper to improve adhesion
- Use a primer if the new color is significantly different from the original
- Apply several thin layers rather than one thick coat
In addition to painting, modifications to handles are also possible. These can be replaced with metal, leather, or wooden handles, which are available online or from specialty stores. Adding decorative trims or drawer liners also creates a personalized touch.
Another option is installing LED lighting in display cabinets or shelves to highlight furniture pieces. It is important to ensure stability and functionality during any modifications to avoid damaging the furniture or compromising its durability.
flota
22 Feb 2021 18:59
As an addition: For customizing the Hemnes series, using self-adhesive films or wallpapers applied to the furniture surfaces is recommended. These methods are relatively easy to implement, can be removed without residue, and allow for a wide variety of designs, from wood looks to graphic patterns.
Additionally, combining color accents by painting the back panels in open shelves or using colored inserts is a good way to create highlights without completely altering the piece of furniture.
It is important to check the compatibility of materials—especially adhesives and paints—before making any modifications to avoid damaging the furniture surface. It is also advisable to perform tests in less visible areas before applying these methods extensively.
Danabla
23 Feb 2021 09:16
I would like to add to the points made by tra_nina and flota with a practical tip regarding handles:
tra_nina schrieb:
In addition to painting, handle modifications are also an option. They can be replaced with handles made of metal, leather, or wood.
A proven approach is also to swap handles for vintage or industrial-style ones, which gives furniture a distinctive look without requiring extensive surface work. It is important to pay attention to the hole spacing to avoid the need for new drilling.
Furthermore, I recommend using suitable chalk paints for larger surface changes, as they require little preparation. After drying, sealing with wax or clear varnish can provide high durability.
Finally, for those who own Hemnes furniture with open shelves, inserting custom-sized shelves made of glass or wood with unique textures can add an extra personal touch.
Devin
23 Feb 2021 16:32
For easy customization:
- Replace handles, preferably check hole spacing beforehand
- Apply adhesive film for a color change
- Add interior lighting, e.g., LED strips
- Highlight covers and trim with color
These are usually simple modifications that can significantly change Hemnes furniture without much effort.
