ᐅ How can IKEA HEMNES furniture be combined with plant styling?
Created on: 25 Jan 2024 09:23
Nulela
Hello everyone, I am currently exploring how to combine Ikea Hemnes furniture with plant styling in a way that doesn’t look cluttered or compromise the furniture’s functionality.
My main focus is on how to blend the clear and rather traditional design language of the Hemnes series with lively, green accents to create a harmonious yet modern atmosphere.
Which types of plants, containers, or decorative elements do you think work best for sideboards, dressers, or shelves from the Hemnes range? And do you have any practical tips for placing the plants so they complement the furniture while also standing out on their own?
Looking forward to your ideas and experiences!
TEOZAR
25 Jan 2024 15:37
To explore the topic further, here is a suggestion based on my experience:
- Hanging plants are well suited for Hemnes shelves, such as pothos or philodendrons, which can be attached to the upper inside of the shelving unit. This way, they don’t take up shelf space but still add a lively touch.
- Combine these with simple, matte clay pots that highlight the natural wood surface of the furniture.
- For dressers or display cabinets, I would choose smaller to medium-sized plants that add structure with their foliage, such as small varieties of monstera or rubber plants.
- An important tip is to pay attention to the room’s lighting. Hemnes furniture often comes in cooler tones, so it’s best to select plants that tolerate low light if necessary.
If you have any questions, I’m happy to help.
GiRoyce
25 Jan 2024 17:50
TEOZAR schrieb:
- An important tip is to pay attention to the room’s lighting. HEMNES furniture often comes in cooler tones, so it’s best to choose plants that can thrive in low light if needed.
I’d like to expand on that, as lighting conditions are often an underestimated factor. This is especially true for white HEMNES furniture, which is frequently placed in cooler rooms. Plants like ivy, snake plant (Sansevieria), or calathea work very well here, as they tolerate shade and add color accents.
Plants with long leaves can also emphasize the vertical aspect of the furniture, such as the snake plant.
Nulela
26 Jan 2024 08:45
nubar schrieb:
Exactly, that’s an important point. Additionally, I recommend considering functionality when styling: plants that need to be watered regularly should be placed on saucers, or you can use plants with water reservoir systems.
Thank you for your previous insights – I find the topic of "functionality versus aesthetics" especially interesting.
What do you think about the idea of placing plants on shelves from the HEMNES series in a way that they provide indirect shade but still receive daylight? Could this make the furniture design more lively? Or would it become too chaotic?
Are there any plants that perform particularly well in such locations, that is, on or in shelves with varying light intensity?
CHENFAR
26 Jan 2024 09:32
Addressing the question: Plants for HEMNES shelves should generally be low-maintenance and adaptable to varying light conditions.
Recommended are:
- Epipremnum aureum (pothos): Tolerant of different light intensities, ideal for indirect daylight.
- Zamioculcas zamiifolia (ZZ plant): Requires little light and water, very resilient.
- Calathea species: Attractive but somewhat more demanding, needing indirect light.
Arranging plants on open shelves naturally presents the challenge of maintaining a neat overall appearance. Moderation and clear layering are important to avoid a cluttered look.
Conclusion: Plants that are flexible regarding placement are best suited for HEMNES shelves, especially when lighting conditions change.
KUDAISY
26 Jan 2024 11:03
Nulela schrieb:
Are there plants that work especially well in places like this, meaning on or in shelves with varying light intensity?
Exactly, that’s a good question. In addition to the plants mentioned, I find Pilea peperomioides very well suited because it does not require direct intense sunlight but prefers a bright environment.
Regarding placement:
- Use plant stands within the shelves to create varying heights.
- Also hang pots slightly staggered on the sides of the shelves, so the plants add visual interest to the furniture without taking up too much space.
This way, you achieve a versatile but not overcrowded overall look.
Elias
26 Jan 2024 13:42
KUDAISY schrieb:
Also hang pots slightly staggered on the side of the shelves so the plants visually add more dynamism to the furniture without taking up too much space.
I really like that, it’s a great tip for adding more life without covering the surface areas too much.
I have also had good experiences with small hanging plants that can be attached using simple holders. This breaks up the overall look, which often works very well with HEMNES and its clean lines.
It probably also depends on the room – in smaller rooms use them sparingly, while in larger spaces you can be bolder.
