ᐅ How can IKEA Brimnes furniture be stabilized?
Created on: 11 May 2023 08:37
dusijo
I have several IKEA Brimnes furniture pieces – including a bed frame and a chest of drawers – and I’ve noticed they tend to be a bit wobbly, especially after extended use.
My question is: What is the best way to improve the stability of IKEA Brimnes furniture without significantly altering the appearance or original structure?
I’m open to practical assembly tips, supportive modifications, or material recommendations that can help enhance the furniture’s sturdiness.
Thanks in advance for your experiences and advice!
te-min
12 May 2023 07:52
Metal brackets on the corners as well as additional cross braces under the platform are very helpful. Don’t forget to retighten the screws.
loken
12 May 2023 10:17
Lorukeo schrieb:
Using metal brackets at critical connection points noticeably improves load capacity.
I agree, I did this on my Brimnes wardrobe and, as expected, no more wobbling! Such simple solutions really work.
Also, it might not be the latest trend, but double-sided mounting tape applied inside tabs or connection points can help reduce noise with minimal effort.
Of course, it’s not for heavy-duty stress, but it’s lightweight and straightforward.
dusijo
12 May 2023 12:49
Nathanaelk schrieb:
Using metal brackets in the corners eliminates weak points. It is advisable to use stainless steel versions here.
Thank you very much for the detailed post, Nathanaelk.
Could you possibly explain in more detail which type of wood glue you would recommend that ideally matches the Brimnes materials and whether there are any stresses or other risks involved when bonding the panels?
I am also interested in whether reinforcing the screw holes afterwards, for example with wooden dowels or wood filler, provides any added value.
Nathanaelk
13 May 2023 08:04
dusijo schrieb:
Could you possibly explain in detail which type of wood glue you would recommend that ideally matches the Brimnes materials, and whether there are any stresses or other risks when bonding the panels?
Sure. For particleboard like that used in Brimnes, a classic white wood glue (PVAC glue) works very well. It is water-based, adheres well to particleboard, and dries clear. Advantages include:
- It penetrates slightly porous surfaces,
- it spreads easily and dries relatively quickly.
Important:
- Always apply glue sparingly to avoid excessive moisture absorption,
- firmly clamp or fix the parts during bonding until the glue has dried.
No stresses or warping are to be expected as long as too much glue is not used and the panels do not become too damp.
Regarding your question about screw holes: I recommend filling enlarged holes with small wooden dowels or wood filler (e.g., Moltofill) before drilling new holes. This provides renewed stability and prevents screws from fitting loosely.
If you want more details on application, I’m happy to assist further.
