I have several IKEA Brimnes furniture pieces – including a bed frame and a chest of drawers – and I’ve noticed they tend to be a bit wobbly, especially after extended use.
My question is: What is the best way to improve the stability of IKEA Brimnes furniture without significantly altering the appearance or original structure?
I’m open to practical assembly tips, supportive modifications, or material recommendations that can help enhance the furniture’s sturdiness.
Thanks in advance for your experiences and advice!
To make Brimnes furniture more stable, I recommend the following measures:
- Check screws and connections: Screws often loosen during assembly or over time. Tightening them usually helps.
- Reinforce the back panels: If only thin particle boards are used, consider adding reinforced plywood sheets or additional cross braces.
- Using metal brackets at critical joints noticeably improves load-bearing capacity.
- For the bed frame, it is worthwhile to install extra support slats in the center underneath the sleeping surface to prevent sagging.
All these measures are reversible and will not affect the appearance if done neatly.
Nathanaelk11 May 2023 10:03The stabilization of IKEA Brimnes furniture is technically feasible but requires attention to certain details:
Generally, particleboard combined with laminated chipboard veneer is not designed for continuous industrial stress. This can cause screw holes to loosen over time or plastic connectors to fail.
Therefore, especially for heavily used parts like the bed frame, I recommend the following points:
- Using wood glue in addition to screws increases joint strength and distributes loads more effectively.
- For screws, you can use longer or stronger wood screws, but be sure to consider the thickness of the wood.
- Retrofitting reinforcements made from plywood or MDF panels on the back or lower surfaces improves lateral rigidity.
- Installing metal brackets in the corners eliminates weak points; it is advisable to choose rust-resistant versions here.
I would also advise against extensive surface modifications, as the Brimnes design is characterized by its concealed edges. Feel free to ask if you need advice for your specific situation.
A small stabilization tutorial for Brimnes furniture:
1. Check the assembly:
- Tighten old screws – they often become loose.
- Make sure all wooden dowels are properly seated.
2. Reinforce the back panel:
- Brimnes models often use simple particleboard that can easily flex.
- Replace or supplement it with a 4mm (5/32 inch) thick plywood panel. This is attached from the inside with small screws.
3. Use metal brackets:
- Especially effective in the lower corners.
- Ensure the brackets are flush and protect the surface if necessary.
4. For the bed frame:
- An additional center beam, preferably solid wood, supports the slatted base and distributes the weight.
Common mistakes:
- Using screws that are too short.
- Omitting glue entirely, which significantly improves load distribution in the joints.
Conclusion: With little effort, the furniture can be made much more stable and durable.
Common mistakes:
There is one important addition to the previous tips:
Please check your Brimnes bed to ensure that the slatted frames rest properly on the support strips and do not shift.
An additional safety measure, such as small wooden blocks or screws, prevents the slats and thus parts of the furniture from moving, which noticeably improves stability and avoids creaking noises.
