ᐅ How can I use BILLY shelves without a back panel, and what are the potential disadvantages?
Created on: 24 Aug 2020 14:03
Tarla
I have a question for the community: How can I effectively use IKEA Billy bookcases without the original back panel? My main goal is to achieve a more open and modern look, but of course, I don’t want stability and functionality to suffer. It would also be great if you could explain the possible disadvantages of using them without the back panel, especially regarding stability, load-bearing capacity, and any potential leaning issues.
Thank you in advance for your tips and experiences!
Oh, that’s brilliant, I love this open look! 🙂
I also use my BILLY without a back panel, but I added a thin plexiglass back that is only attached on the sides. This keeps the openness while providing support.
A tip from me: don’t forget to mount it to the wall, especially if you have children or the shelf is very tall!
Pome60 schrieb:
I also run my BILLY without a back panel, but I solved this by adding a thin Plexiglas back, which is only fixed at the sides.That’s a good idea! However, I would like to know how much a Plexiglas sheet actually contributes to stiffening compared to the original back panel. Plexiglas is relatively thin and flexible. Are there any reliable practical experiences regarding this?
Additionally, the question is whether the shelves can be loaded evenly with such modifications without causing sagging or tilting. Stability through wall mounting is certainly crucial, but the frame construction is also important.
Regarding stability: Wall mounting is mandatory if there is no back panel. Otherwise, you can forget about the shelf—it will tip over too easily.
Depending on the height and width of the shelf, reinforcements on the sides or underneath can help. But the most important thing is really the wall mounting!
theo63 schrieb:
I would like to know how much a plexiglass panel actually contributes to stiffening compared to the original back panel.Good question! An original BILLY back panel made of wood fiber material (MDF/particleboard) is relatively rigid and prevents twisting very effectively.
Plexiglass looks great but is noticeably more flexible in terms of stiffness and tends to bend. If you use plexiglass, the panel should be relatively thick (at least 4–6 mm (0.16–0.24 inches)) and kept as flat as possible to provide some stability.
Additionally, you should fix the plexiglass back panel at several points so that it really acts as reinforcement. However, this only partially replaces the original back panel.
For optimal stability, wall mounting and additional brackets are still necessary.
Thank you for the many detailed responses!
In summary, I understand that removing the back panel can be an aesthetically pleasing solution, but it definitely requires additional measures such as wall mounting and side reinforcements to keep the shelf stable.
I find the idea of using plexiglass as a back panel substitute particularly interesting, even though it probably doesn’t provide the full stiffening effect. I think I will need to experiment a bit with that.
If anyone has advice regarding the placement of heavy items on the open shelf, that would be great. How important is it to concentrate the weight at the bottom?
