ᐅ How can I retrofit Ikea Metod cabinets with a soft-close feature?
Created on: 24 Jun 2024 08:43
FARTURNER0
FARTURNER0
24 Jun 2024 08:43
I have a question about retrofitting the soft-close function for Ikea Metod furniture, specifically the base cabinets. I own several Metod kitchen cabinets that currently do not have any dampers or soft-close features. Since I really appreciate the convenience of a gentle closing, I would like to add this function afterward without having to replace the entire drawer or furniture system.
I am aware that Ikea sells individual soft-close fittings and hinges that can be installed directly, but I am wondering if there are practical solutions that can also be used with already assembled furniture—such as retrofit kits or universal dampers that can be attached. Are there any special considerations regarding the compatibility of the dampers with the existing drawer runners or hinges?
What is the best way to retrofit Metod furniture? Do you need to completely remove the drawer or front panel? And how durable are these retrofit solutions in everyday use?
I would appreciate concrete tips, product-specific recommendations, and personal experiences, ideally with advice on where to get the best dampers at a good price and what to watch out for during installation.
Thanks in advance!
juMira46
24 Jun 2024 09:18
Hello FARTURNER0,
great question, which actually interests many Ikea fans! The soft-close feature is simply essential for that added comfort and really enhances your Metod furniture.
Basically, there are two options:
- Ikea sells soft-close hinges and dampers specifically designed for Metod, which you can easily replace by removing the old hinges completely. This is the cleanest solution but requires some effort.
- For retrofitting existing drawers, there are also universal soft-close dampers that can be attached, for example, to the side or back of the drawer slides. Unfortunately, the quality varies a bit here, often they are a little noisier and not as durable as the originals.
Regarding installation: Yes, in most cases you need to remove the drawer or door to properly install the dampers. Sometimes fastening at existing screw positions is enough, sometimes small pilot holes need to be drilled. I recommend examining the mechanism carefully before purchasing and deciding whether you prefer original parts or a DIY solution.
Tip: Check which drawer slides you have (Metod usually uses Tandembox or similar), as soft-close dampers are often specifically designed for those.
Good luck and happy virtual screwing!
Filippo
24 Jun 2024 14:07
- Ikea sells soft-close hinges and dampers specifically for Metod, which you can easily replace by removing the old hinges entirely. This is the cleanest solution but requires some effort.
- For retrofitting existing drawers, there are also universal soft-close dampers that you can attach, for example, to the side or back of the drawer slides. The quality varies somewhat here; they are often a bit noisier and less durable than the originals.
In addition, when retrofitting soft-close on Metod, I recommend paying particular attention to the type of drawer slides. Ikea usually uses Blum Tandembox or Metabox slides, which are available in soft-close versions. Replacing the entire slide with an integrated soft-close damper is the most durable method.
If you want to keep the existing slide, there are so-called clip-on dampers that can be mounted on the sides of the drawer. However, precise installation is required here; otherwise, the soft-close function may not work properly, or the drawer might stick when closing.
The ideal installation process is as follows:
- Remove the drawer and take off the front panel.
- Remove the old slide including the damper (if replacing).
- Install the new slide with integrated soft-close function, making sure it is precisely aligned.
- For clip-on dampers: determine the exact position according to the instructions, use screws in pre-drilled holes or carefully pre-drill if necessary.
Also, make sure that the maximum load capacity and the dimensions of your drawers are compatible with Metod furniture. Cheap universal dampers can distort the drawer or damage the mechanism if installed incorrectly.
In summary: for lasting quality, replacing the entire slide is the better solution. Retrofit kits can be a quick fix during the transition phase, especially if the budget is limited.
If you want, I can also provide exact product names for suitable slides. That might help you with your search.
pikin
25 Jun 2024 07:19
Filippo schrieb:
For lasting quality, a complete replacement of the drawer slides is the better way to go.
I fully agree. Replacing the existing drawer slides with built-in soft-close function is the cleanest and most durable technical solution. The original Ikea ones or compatible Blum versions work perfectly for this and guarantee optimal performance.
- Remove the drawer and take off the front panel to work without obstructions.
- Remove the old slides; screws for the front panel hinges are usually easily accessible.
- Align the new soft-close slides precisely horizontally to ensure smooth drawer movement.
- Reattach the front panel and test the function.
Also note that not all Metod drawers have the same slides. There are different rail systems with slightly different mechanics, so you should measure and check the model before purchasing.
Universal retrofit dampers are more of a compromise for low cost or as a temporary solution. Their load capacity and precision are less reliable.
If you have some DIY skills, investing in new slides is definitely worthwhile.
