I have an IKEA Platsa wardrobe at home where the back panel is damaged. It’s the thin MDF board that is fitted at the back, and unfortunately it is torn in several places and warped. As a result, the cabinet no longer stands completely straight and the stability seems compromised.
My question is about the best way to replace or repair the back panel. Does IKEA offer replacement parts that I can order directly, or would it be better to have a new panel cut to size myself?
It would also be helpful to know if there are specific recommendations for the material and thickness in case I need to source something on my own.
Maybe someone has experience with this and can share helpful tips on how to dismantle and reattach the back panel so the cabinet remains stable and straight.
Thanks in advance for your support!
warrenka571 Dec 2023 10:11narDietmar schrieb:
If your cabinet is located in areas with higher humidity (kitchen, laundry room), I recommend choosing a suitable coated or impregnated back panel.This is a very important tip! My cabinet was initially in the bedroom, but later moved to the kitchen—and I definitely noticed differences in the back panels. The simple thin MDF back panel became warped and brittle after a few years there.
Therefore, I can only suggest factoring in the moisture conditions when making your choice.
Also, I wanted to point out that the back panel is not just about aesthetics; it is crucial for the cabinet’s stability, which cannot be ensured without an intact back panel.
warrenka57 schrieb:
Also, I wanted to point out that the rear panel is not just about aesthetics but also crucial for the cabinet’s stability, which is lost without an intact back panel.Exactly, many people underestimate this. The back panel prevents the cabinet frame from twisting and is therefore essential. I also recommend inserting the small nails at an angle when attaching the back panel, as this helps them hold better.
Another tip for replacement: If you remove the old back panel completely, check for old nail holes beforehand. You can fill these with putty before installing the new panel, which makes the surface smoother and visually more appealing.
By the way, sometimes a damaged back panel can be repaired with wood glue and small strips of MDF if the damage is not extensive – this can work as a temporary solution.
Hi annika62,
great topic! I recently did a similar repair myself and found it wasn’t as difficult as I initially thought. The key is to approach it calmly and patiently.
If you get a new back panel, don’t stress over millimeter differences – the cabinet modules are somewhat forgiving in certain areas anyway. What’s more important is that the panel fits securely overall.
I enjoyed finding a lightweight MDF panel type with a smooth surface. And here’s a useful tip: after inserting the back panel, fix it in place on the sides with thin wooden strips for extra stability!
Hang in there, you can do it!
