Hello everyone, I am looking for ways to repair my IKEA Malm furniture after purchase. Specifically, I need to address some minor damage such as scratches, chipped edges, and loose screws on dressers and nightstands from the series. I am particularly interested in which materials and tools are best suited to effectively fix these issues without affecting the typical finish of the Malm furniture. Are there any proven methods or special repair kits you would recommend? I would appreciate it if you could share your experiences or detailed instructions so I can repair my furniture as professionally as possible myself.
Hello Sageta,
your question is very well formulated and includes many important details. Malm furniture is often sensitive to edge chipping and scratches due to its veneered particleboard construction. Therefore, repair requires a careful approach to preserve the original matte finish.
First, you should address any loose screws: it is recommended to fill loose holes with wood filler, let it dry thoroughly, and then tighten the screws again using a slightly smaller screwdriver. For the scratches, you can use special furniture touch-up markers available at hardware stores in color shades. It is important to test the marker before use, and for deep scratches, gently roughen the damaged area first with fine sandpaper (grit 400-600).
Chipped edges are trickier. Since the thin foil or melamine coating is usually missing here, I suggest using a two-component adhesive that can be lightly sanded after curing. Afterwards, you can blend the surface using a special touch-up marker or even finer sandpaper. Make sure the furniture is clean and dust-free during all steps.
What kind of damage do you have exactly? Are these only small nicks, or are larger surface areas affected as well? This will help to make the recommendations more precise.
warrenka5726 Nov 2024 10:06I fully understand how frustrating these minor damages can be, especially on furniture that has seen daily use for a long time. For light scratches, I have found furniture wax sticks to be effective, as they not only fill in the damage but also contain wood care agents. For broken edges, it was important to be patient and apply adhesive in several layers, sanding between each; this takes time but restores a good appearance.
My advice: try it first on an inconspicuous area to get a feel for the materials. This also helps reduce the uncertainty I initially experienced.
The topic of repairing Malm furniture is interesting because only those who understand the material’s distinctive characteristics can make durable and inconspicuous repairs.
This is exactly the tricky part: color matching is essential. I recommend first doing a small color test on a cut-off scrap piece (or the back side) to ensure the marker doesn’t appear unintentionally darker or lighter. Using overly aggressive abrasives can severely damage the veneer surface, which will always be noticeable later on.
For edges, depending on the damage, it usually makes more sense to apply small veneer strips with wood glue and sand them down instead of just using adhesive. This restores texture and strength. If you’re interested, I can provide a step-by-step guide for edge repair with veneer strips.
How precise do you want the repair to be? Is your focus more on functionality or achieving a visually perfect result?
Dilen schrieb:
For scratches, you can use special furniture markers in various shades available at hardware stores.
Thank you all so far for the helpful suggestions!
Regarding the details: The damage is actually quite minor, mostly affecting the top edges of a dresser (about a 10–15cm (4–6 inch) area chipped) and a few superficial scratches on a nightstand. Some screws are slightly loose but not completely wobbly yet. The furniture still functions perfectly. I bought some small furniture pins but am unsure about the edges – in my previous attempts, the material looked somewhat unnatural and dull.
In the long term, it’s important to me that it looks neat, but not professional-level. However, if the process is a bit more involved and can be done by following instructions, I do have the time and patience. The dresser has a matte white finish. Even if something isn’t 100% perfect, that’s acceptable to me as long as it blends in harmoniously.
Palenar schrieb:
How precise do you want the repair to be? Are you more concerned with function or visually perfect results?
