ᐅ How can I protect Malm dressers from moisture?
Created on: 29 Oct 2020 09:37
Jassim62
I have a somewhat technical question that perhaps someone here has already solved: How can I effectively protect Malm dressers, which are in my bedroom, from moisture? Specifically, I am concerned that due to humidity and occasional ventilation, the dressers are sweating or absorbing a small amount of moisture, especially on the back panels and bottom boards. This not only causes unattractive discoloration but I am also worried that the material might suffer damage over time.
I am not looking for complicated or expensive solutions, but rather practical ones that work in everyday use. What methods or tips can you recommend to protect wood or particleboard furniture like the Malm dresser from moisture? Are there any proven home remedies, special sealants, or technical aids that are effective? Maybe you also have experience with indoor climate factors that should be considered.
Thanks in advance for your advice!
PERON
30 Oct 2020 09:07
Domau0 schrieb:
What is the relative humidity where you are?
Good question, because sometimes the issue isn’t with the furniture itself, but with the microclimate. I had a similar problem in the corner where we placed the dresser. Only after I put a small hygrometer there did I realize that the humidity was constantly around 75%.
My advice: Measure the moisture first before applying any paint or oil. You don’t want to waste time experimenting unnecessarily ;-)
Heating also helps, as warm air can hold more moisture and increases drying time.
liste
30 Oct 2020 09:30
PERON schrieb:
First measure moisture before applying any paint or oil.
I agree with that – but measuring alone won’t help in the long run. Is the exterior wall insulated or just a simple wall? Often, incorrect insulation causes moisture levels to remain high, so all measures only address the symptoms.
Are there specific details about your living situation, Jassim62? Otherwise, we might waste time with half-hearted advice.
Jassim62
30 Oct 2020 13:18
Domau0 schrieb:
What is the relative humidity like where you are? Is the dresser placed against an exterior wall or an interior wall? How do you use the rooms (heating, ventilation habits)?
Thanks first of all for the many helpful suggestions.
The dressers are located against a slightly north-facing exterior wall, which often gets colder in winter. I measure the humidity in winter between 55% and 70%, depending on ventilation and heating. Heating is provided by a central heating system, and I usually ventilate twice a day with shock ventilation.
The moisture on the dresser is mainly barely visible on the backside, hardly noticeable to the touch, but it is visually a problem that bothers me. Otherwise, the surface is mostly intact.
I haven’t done anything yet to protect the edges, but I would like to start that now. Are there any recommendations for which varnishes or sealants should be used specifically for this type of coating?
I’d appreciate specific product names or links if anyone has experience.
Unfortunately, a dehumidifier is not (yet) available, but that would certainly be the next option.
Domau0
30 Oct 2020 15:42
Jassim62 schrieb:
Are there any recommendations on which paints or sealants should be applied for this kind of coating?
For your situation, I recommend two options:
- "Clou edge protection varnish for MDF and particle boards": This water-based varnish is flexible, forms a clear protective layer, and prevents moisture from penetrating the edges.
- Alternatively, "Owatrol Huile-Rustol": This is an oil-wax that protects and impregnates the material. For Malm dressers, you can apply it thinly to edges and backs, being careful due to the melamine surfaces.
Be sure to test on a hidden area beforehand!
If you have very cold exterior walls, adding a PE film as a vapor barrier behind the dresser against wall moisture might also be useful (self-adhesive or applied with double-sided tape).
I’m happy to keep you updated if you have more questions.
