ᐅ How can I modify Ikea Platsa units for use in an office?
Created on: 27 Apr 2021 09:37
Gazar
Gazar
27 Apr 2021 09:37
I am currently considering the idea of adapting the Ikea Platsa system for use as office furniture. My specific question is: How can I modify or expand the modular Platsa system to provide optimal functionality and ergonomics for a workstation? I am particularly interested in practical tips for installing desktop surfaces, integrating cable management, storage solutions for office supplies, and ways to improve stability, as I plan to use the system for more intensive use. Of course, it would also be great if you could share your experiences with useful additions such as drawers, lighting, or organizational aids.
Thank you in advance for your expertise and advice!
draleo
27 Apr 2021 11:03
For using Ikea Platsa in an office setting, I recommend the following steps:
- For the desk surface, mount a suitable worktop (e.g., Ikea Linnmon or a standalone top) on top of the Platsa modules and secure it with angle brackets to ensure stability.
- Cable management can be achieved using cable ducts on the back or inside the modules; adhesive cable clips also work well for this purpose.
- Storage for office supplies can be arranged with open compartments and closed doors; use inserts and small boxes that integrate into the system for organization.
- To increase stability, cross braces or additional screws at the joints can help, as the series is designed more for light use.
- Additional lighting can be installed with LED strips under the top board, which can be easily powered by a plug-in power supply.
These modifications make the Platsa system versatile and suitable for everyday office use.
minan
28 Apr 2021 14:52
Hello Gazar,
I find your idea very interesting, as the Ikea Platsa system is originally designed for living spaces but offers great potential for office applications due to its modularity. However, if you want to use it long-term and ergonomically, I recommend careful planning:
- First, it is important to consider the working height. Standard Platsa modules have a height that is not directly suitable for a desk. You could stack several modules to achieve a working height of about 72-75 cm (28-30 inches), or use a custom worktop. It is advisable to use Platsa units as base elements and fix a sturdy tabletop on top, such as plywood or a coated chipboard with sufficient weight.
- Cable management is essential. Platsa offers back panels with openings that you could enlarge to route cables neatly. Attaching small cable grommets to the work surface also helps. If you use multiple devices, it’s a good idea to install cable ducts on both sides and bundle the cables neatly with zip ties or clips.
- Storage can be effectively set up with a combination of open compartments and drawers. You can use Ikea’s own inserts or integrate universal organizers into the system if you need to store many file folders or office accessories.
- Stability is an often underestimated factor. Since Platsa is relatively lightweight, I recommend using additional corner brackets or thin plywood strips mounted on the inside edges. This prevents wobbling, especially if you connect larger worktops or several modules.
- Lighting can be integrated with LED strips under the worktop or in shelving – dimmable would be ideal. Make sure to use safe wiring and ensure easy access to switches for power supply.
What kind of work environment are you setting up? Will multiple people use the system? Are there any specific requirements for sound insulation or materials I should know about?
Gazar
28 Apr 2021 16:08
minan schrieb:
What kind of work environment do you have? Are multiple people working on the system? Are there any specific requirements for sound insulation or materials that I should know about?
Thank you for the detailed explanations, minan. My situation is a single workstation in a quiet home office. It is important to me to have a large, as flexible as possible, storage space for files, folders, and electronic accessories. The system should be compact since the room is limited, but still offer a lot of volume. Ergonomics are important, with a working height of about 73 cm (29 inches). Sound insulation is less critical; what matters more is that the surface is easy to maintain and clean. Additionally, I would prefer an option to attach simple supplementary lighting directly to the furniture. Perhaps you can provide further advice based on this description?
Giagau
29 Apr 2021 08:41
Gazar schrieb:
The system should be compact due to limited space but still offer a lot of volume. Ergonomics are important to me, with a working height of about 73 cm (29 inches).
The note about the working height is very important. I recommend starting with two Platsa modules placed side by side to create sufficient width and storage space. To achieve the optimal working height of around 73 cm (29 inches), it’s better to use a separate, sturdy tabletop—such as a plywood panel approximately 28 mm (1 inch) thick—mounted on the modules. Use robust brackets or clamp systems to securely fix the tabletop and prevent twisting.
- For storage, combine closed and open elements. Upright compartments with suitable shelves are ideal for files or binders.
- Improve cable management by drilling holes for cable grommets in the tabletop and then using flexible cable channels or spiral wraps.
- You can attach LED strip lighting underneath the tabletop; choose a dimmable, warm color temperature that is easier on the eyes, especially during extended use.
These measures will ensure functionality, stability, and comfort in your confined workspace.
