ᐅ How can I restore the stability of Malm furniture after moving?
Created on: 7 Jul 2019 08:23
U
USAYKUT
U
USAYKUT
7 Jul 2019 08:23
Hello everyone, I have the following problem and hope for your experience and good tips: After moving, my IKEA Malm furniture – specifically dressers and bedside tables – have somehow become unstable. They wobble at times and creak, which annoys me a lot because I plan to use them permanently. Does anyone know tricks or proven methods to make these pieces stable and load-bearing again? I am interested in all aspects, such as tightening screws, using wood glue, reinforcing the joints, or special techniques to restore Malm furniture to a firm and secure condition after a move. Thanks in advance for your help!
sarlo
7 Jul 2019 09:41
Hello! Your concern is completely understandable. Especially during moves, furniture like Malm can become a bit unstable because the joints experience more stress. Generally, it’s worth starting by tightening all screws and fittings – they often loosen over time.
If the joints are already a bit worn out, wood glue can help to re-secure dowels or paired glued parts. It’s important to firmly clamp the furniture while the glue dries – either with clamps or at least by pressing it firmly against a surface.
Another option is to reinforce the interior corners with small metal brackets, which you can attach from the inside. This often makes a big difference. Good luck!
EDWARD0
7 Jul 2019 11:12
Completely unscrew the screws, clean the threads and screws, and use a new set of screws if necessary. Use wood glue only for permanent fixation, then clamp. Reinforce angle brackets indoors if possible, ensuring precise fitting during installation.
Nauman5
7 Jul 2019 13:47
That sounds like a small DIY project with a great sense of achievement! 🙂
sarlo schrieb:
It’s important to secure the furniture well while it’s drying
I always underestimate that too. After moving, my Malm chest of drawers got a new lease on life just for that reason – a few clamps, some patience, and voilà, no more wobbling. Oh, and a bit of tapping and readjusting never hurts 😉 I can really relate to that!
karus66
8 Jul 2019 10:05
I think your suggestions are good, but I would like to add that it’s important to carefully check whether the piece of furniture is already affected by material fatigue. Malm is known for its comparatively thin particleboard – after a move, slight cracks or weakened joint connections can appear.
This is true, but if the threads in the wood are already worn out, this often won’t help anymore. As an alternative, I recommend re-drilling and reinforcing with thicker wooden dowels or special threaded inserts.
Although this is somewhat more labor-intensive, it provides long-term stability. Simply tightening screws again is often only a temporary fix.
pakokla
8 Jul 2019 12:36
Short and practical: Secure screws with threadlocker (Loctite) if the threads are still in good condition. For worn-out holes, use wood filler or insert wooden dowels, then re-screw. Angle brackets on the inside are often the best and easiest reinforcement.
