I own several Malm furniture pieces from Ikea, especially dressers and nightstands, where the drawers creak or squeak quite loudly when opening and closing. My question is: how can I make Malm furniture operate silently? I’m looking for simple and durable solutions that are easy to implement. Are there any specific lubricants, liners, or structural modifications you would recommend? I’m also interested in options that won’t cause any damage, meaning no visible marks or permanent alterations. Thanks in advance for your tips and experiences!
Hello Lau-se8,
your question is very well formulated and addresses a common issue with Malm furniture. The typical squeaking often comes from the wooden supports and sometimes the unprotected metal drawer slides.
I recommend first removing the drawers completely and applying a dry lubricant to all sliding surfaces, such as a special silicone spray or beeswax. The latter is especially good because it doesn’t become sticky and does not attract dust particles.
Another tip is to attach felt or foam rubber strips to the contact areas—where the drawer slides along the cabinet frame. This not only reduces noise but also protects the wood from scratches.
It is important to make sure that the drawers are not too loose, as this can cause vibration and more noise. You can also check whether the screws holding the drawer slides are tightened properly.
If you prefer no visible modifications, self-adhesive felt strips are a good option and can be removed without leaving residue.
If you like, I can explain some points in more detail!
Hello Lau-se8,
I would like to delve a bit deeper into your topic from a technical perspective. There are two main causes of noise in Malm drawers: first, the friction between wooden surfaces (e.g., the drawer bottom and the cabinet), and second, the guide rails and their rollers or metal sliding elements.
Step 1: Remove the drawer and thoroughly clean all contact surfaces. Dust, crumbs, or other fine particles may have accumulated, which can cause noise.
Step 2: For the metal guides, I recommend using a dry lubricant (such as PTFE spray or silicone spray). These reduce friction without causing dirt buildup that could shorten the lifespan.
Step 3: For wood-on-wood contact points, you can either use felt strips or reduce friction with special waxes or paraffin. These are also discreet and can be removed without leaving residues.
Step 4: Check the stability of the guide rails. Loose screws can cause vibrations and are a common source of annoying noises. Carefully tighten them.
Step 5: If your drawer uses rollers, inspect whether they are intact; if necessary, they can be replaced.
One more note: some users report that cutting small wooden strips to seal certain gaps helps, but be cautious not to damage the furniture.
It would be helpful to know exactly what type of drawer slides are installed in your case—could you describe them in more detail?
Domau0 schrieb:
What exact type of drawer slides are installed in your case is important, could you describe that in more detail?Thank you for the detailed response, Domau0. The slides are simple metal runners with plastic gliders, not rollers. The drawers run fairly directly on the slides, without any complex mechanisms. I also notice that the sides of the drawers occasionally rub slightly against the cabinet frame.
The screws seem tight, but I will check them again. Felt strips sound like a good idea, though I wonder how durable such a solution is in the long term.
Has anyone had experience with the longevity of felt or foam rubber adhesive pads in these areas?
Lau-se8 schrieb:
Has anyone had experience with the durability of felt or foam rubber stickers in such spots?I had the same issue with my Malm dresser. The felt strips stayed firmly in place for over a year and really reduced the noise significantly. I always use self-adhesive felt pads for this, which you can find at hardware stores.
After a while, they sometimes start to peel at the edges, but that’s easy to fix. I’ve found it’s better if the strips aren’t too thick; otherwise, the drawer can get stuck when closing.
It’s also important to thoroughly clean the surface beforehand, otherwise the adhesive won’t stick well.
Other than that: don’t worry, you can remove or replace the strips at any time without leaving any residue.
