ᐅ How can I damage MALM dressers without assembling them?
Created on: 27 Jul 2022 14:37
Kentau
Kentau
27 Jul 2022 14:37
I have a somewhat unusual question and hope to find some experienced opinions here: How can IKEA MALM dressers be damaged without assembling them first? I am actually trying to identify weak points or sensitive areas where the furniture could get damaged while still packaged – for example, during transport or storage. I suspect that certain parts like edges, back panels, or connection surfaces might be especially vulnerable without assembly since the structural support from building it is missing. Does anyone have experience or tips on what kinds of actions or stresses cause the most damage there – such as pressure, impacts, or improper storage?
I am mainly interested in a practical assessment: Which mechanical forces should be avoided to keep the MALM dressers as intact as possible? Or, conversely, which factors quickly cause visible or permanent damage to the original condition? Looking forward to your answers!
Charles
27 Jul 2022 15:02
The question of how MALM dressers can be damaged without assembly is quite interesting and requires a detailed look at their construction and packaging.
The main cause of damage to unpackaged or unassembled furniture is usually localized pressure on sensitive surfaces, especially at the edges. The back panel of MALM dressers is typically made of thin fiberboard, which can easily tear or be punctured if it comes into contact with harder or sharp objects.
Stacking multiple unpackaged boxes or placing them on uneven or sharp surfaces can also damage the packaging surface and, consequently, the underlying furniture panel. Without the assembled frame, the carcass is not yet stabilized, so even relatively minor impacts or bending on the side panels can cause deformation.
Therefore, it is particularly important to consider the following points:
- Do not place sharp or heavy loads directly on the packaging
- Store the dressers flat on as smooth a surface as possible
- Ensure impact protection with padding or secondary packaging during transport
The key is to avoid stresses beyond simple pressure loads, which can cause localized failure of the loose component structure.
Palenar
27 Jul 2022 17:48
I would like to explain this in more detail, as there are some small technical details regarding MALM dressers that are important for your concern.
In its unpacked, unassembled state, the piece of furniture lacks real rigidity. The individual panels – such as the top, sides, and back panels – are quite thin and relatively flexible on their own. For example, the hardboard back panel significantly contributes to the stability once it is installed and secured with screws.
Until then, however, the back panel is a weak point: any impact with a sharp object or edge can easily cause cracks. The box provides some protection, but without additional padding, breakage can still occur during transport or storage.
Charles schrieb:
The back panel of MALM dressers is usually made of thin hardboard material that can easily tear or puncture
That describes it very well. It is also helpful to know that the edges of the support sides (side walls, front, and back panels) are especially vulnerable when they are not securely connected. Depending on how the box is cut and folded, these surfaces are the most likely places for localized pressure from edges, corners, or impacts to cause damage by breaking the paint or film finish on the panels.
Another important point is storage: If the dresser, packed in parts, is stored upright on its long side for an extended period, the panels can deform under their own weight due to lack of support. In other words, the risk of “deformation fractures” on side or bottom panels increases.
Kentau schrieb:
Does anyone have experience or tips on which actions or stresses cause the most damage – for example, pressure, impacts, or improper storage?
It would be helpful to know whether your focus is primarily on protection during transport in the packaging, or if you mean damage caused by improper handling in storage (for example stacking, tipping, or turning the unit upside down or on its side)?
To intentionally damage the dresser “without assembly,” I would say the fastest way to cause harm is by applying pressure or strong bending to areas with sharp corners, or by exerting strong pressure on the back panel.
lajudo
28 Jul 2022 08:31
If you want to damage MALM dressers without disassembling them, focus on the back panel. It is the thinnest part and breaks easily under pressure or impact.
The board where the drawers are later attached is often unstable as well. Bending it can cause damage.
Avoid storing the dresser upright for extended periods, as this can lead to warping.
Matthewt48
29 Jul 2022 11:12
I find this question interesting because it addresses an often overlooked aspect of furniture handling. MALM dressers are quite simple in construction, which means that without assembly, there are inherent weak points.
As Charles and Palenar have already explained very well, the back panel is the main area of concern. Without assembly, stabilization is missing, especially along the edges and connection points.
When it comes to deliberately damaging unassembled MALM dressers, there are a few additional considerations: localized force applied to the hinge areas or to the drawer guide components can cause deformations or breaks, even if these parts are still loose.
The surface finish should also be mentioned: the edges of the packaging or rough surfaces can easily scratch or damage the finish. Especially with laminated panels, this results in unattractive scratches or abrasions that are not easy to repair.
Palenar schrieb:
It would be interesting to know whether your focus is more on the protection during transport within the packaging, or if you mean damage caused by improper handling in storage (e.g., stacking, tipping, turning upside down/sideways)?
Because that makes a difference: in pure transport, damage is more likely caused by impacts and multiple handling, whereas in storage or during handling, damage can result from continuous pressure, incorrect stacking, or leaving the item on uneven surfaces.
If Kentau could provide more detail about the circumstances in which the damage occurs, more targeted advice could be given. In general, however, the cardboard packaging provides only limited protection against localized forces on thin components.
