ᐅ How can I customize the color of Billy shelves?
Created on: 13 Mar 2018 08:42
evanri
evanri
13 Mar 2018 08:42
Hello everyone, I am considering customizing the color of my Ikea Billy shelves to better match the color scheme and furniture in my living space. I have thought about painting, applying adhesive film, or using vinyl wrap, but I am unsure about the advantages and disadvantages of each method, which materials adhere best, and how to properly prepare and treat the shelves to ensure a durable result. Can you give me tips on how to optimally customize a Billy shelf without compromising its stability or functionality? I am especially interested in clever techniques and common mistakes to avoid.
Kyleli
13 Mar 2018 09:13
Hello evanri, just sand, then prime and paint with acrylic or enamel paint. If you use foil, make sure the surface is smooth and well dusted. You don’t need anything else.
PRA64
13 Mar 2018 11:27
Hello evanri, I’m happy to give you a structured guide: First, thoroughly clean the surface and lightly sand it to roughen up the plastic coating of the Billy shelves. This greatly improves the adhesion of paint or adhesive film. After that, it’s recommended to use a special plastic primer, for example from 3M or Rust-Oleum. Avoid using standard wood or metal primers, as they usually do not adhere well.
Next, you can either use acrylic paints if you want a matte and durable finish, or spray paint for an even coating. Important: Apply several thin layers instead of one thick one. After drying, you can seal the surface with a clear coat, which helps protect against scratches and water.
If you prefer to use adhesive film, I recommend high-quality self-adhesive films designed for furniture, such as those from d-c-fix. Before applying, cut the film to size, dust the surface thoroughly, and ideally smooth it out with a squeegee. Make sure to avoid trapping air bubbles.
Common mistakes include insufficient preparation, applying paint too thickly, using the wrong primer, or applying adhesive film on surfaces that are too rough.
If you have any technical questions, just ask!
Annedeo
14 Mar 2018 07:56
Hello evanri, I would like to add that besides painting and applying adhesive films, there is also the option to paint the Billy shelves with special furniture paints (chalk paint), which create a velvety, matte finish and do not require a strong base. These paints are often very opaque and can be applied without extensive sanding, saving time and protecting the surface.
evanri schrieb:
I’m especially interested in clever techniques and mistakes to avoid.
It is important to consider the compatibility of the paint color with the room: light colors create a more airy feel, while dark colors appear more compact and modern. A combination of painted fronts and openly visible natural white shelves can create a nice contrast.
Avoid repainting stained surfaces without sanding to prevent flaking. Also, do not use coarse sandpaper, as it can cause visible damage.
If you like, I can provide tips on which products are best suited for different surfaces and room types.
O
onron
15 Mar 2018 13:46
An important factor is the long-term durability and maintenance of the surface. If you paint the shelves, a matte or satin acrylic paint is best, as it is durable and relatively resistant to scratches. High-gloss paints may look stylish but show signs of wear more quickly.
Annedeo schrieb:
Also, you shouldn’t use coarse sandpaper, or it will leave visible damage.
I agree with that. I usually use sandpaper with a grit of 220 to 320, which is fine enough to sand without leaving visible scratches.
Another tip: If you want to match a color to an uneven wall paint, matte or slightly textured paints work better because they help conceal imperfections.
If you decide to use adhesive film, make sure the film is suitable for furniture and durable. I especially advise against cheap films, as they tend to develop cracks or bubbles quickly.
blapau
16 Mar 2018 09:33
To add a personal touch, you can also use paint or wallpaper on the inside of the Billy bookcases. This creates a striking contrast between the exterior and interior.
PRA64 schrieb:
Important: Apply several thin coats instead of one thick coat.
This is very important because thick paint layers often dry unevenly or can form bubbles.
Another creative option is to use stencils or stamps after applying the paint to create patterns. Just make sure the base coat is completely dry before adding these details.
Do not neglect drying times and always work in well-ventilated rooms.
