ᐅ How can I carefully dismantle IKEA Metod cabinets when moving?
Created on: 15 Aug 2023 10:07
ralf59Hello everyone, I am preparing to move and have some IKEA Metod kitchen cabinets that I want to carefully and professionally disassemble in order to reassemble them at the new location without damage. My question is which methods you would recommend to avoid damaging the cabinets during disassembly, especially regarding the handling of fasteners, the carcass panels, and the cabinet fronts. Are there any tools or techniques that have proven effective, particularly concerning the fragile edges and the hinges? I already have the impression that taking them apart is not straightforward, especially if you want to reuse the parts later. I would be very grateful for any tips or experiences!
ralf59 schrieb:
My question is which methods you would recommend to avoid damaging the cabinets during disassembly, especially regarding the handling of the connectors, the carrier boards, and the fronts.In my opinion, you can be a bit cautious with IKEA Metod – the parts are surprisingly sturdy. Of course, you shouldn’t pry out screws and dowels with brute force, but I like to see dismantling as a kind of creative puzzle, sometimes even requiring a bit of improvisation. The important thing is to always remove the fronts first, so nothing gets scratched and you still have good access later.
The tool should be a cordless screwdriver with the correct bit; definitely not just manual work, as that will only cause frustration. And don’t be put off by the small metal connectors – they are made from tough material and can withstand quite a bit.
As for the connectors themselves, I wouldn’t necessarily reuse them. Eventually, everything fits too tightly or the plastic parts become worn. It’s better to buy new ones to avoid surprises when rebuilding.
Finally: eventually everything is taken apart – and yes, you might scratch a corner here and there, but don’t panic, that rarely makes the cabinet unusable.
warrenka5716 Aug 2023 09:38karlau schrieb:
I wouldn’t necessarily reuse the fasteners themselvesI understand why you say that. I moved last year with similar cabinets and was also unsure whether to keep everything original. What helped me was taking my time beforehand and documenting every step. Sometimes I also took photos to remember how the joints fit together.
Sometimes it was painful to take the cabinets apart—it almost felt like dismantling a familiar piece of furniture. But it went much smoother than I expected. Be gentle and patient.
And for anyone unsure: after disassembly, pack the parts carefully—for example, put the hinges in small bags so nothing gets lost. This way, you feel much better prepared afterward.
Maybe my approach can help someone here.
ralf59 schrieb:
especially regarding the handling of the fasteners, the mounting plates, and the fronts.Interesting question, since many people underestimate the load capacity of the fittings and the potential mistakes during disassembly.
The Metod series primarily uses Minifix dowels and connectors, which are sturdy but can be stressed mechanically if handled with unsuitable tools or excessive force. It is therefore advisable to carefully and systematically loosen each connector, preferably with a tool matched to the screws.
The mounting plates (back panels) are often only glued or nailed – you should work very carefully with a thin prying tool here to avoid damaging the panel, as this often affects stability when rebuilding.
Another important aspect is documenting the installation, for example with small markings or photos. This may seem trivial, but especially with more complex kitchen cabinets, it can prevent many errors during reassembly.
Finally: For those aiming for durability, it’s worth checking the fittings for any wear before reuse – because even though Metod is solid, plastic or metal parts can lose their grip after repeated use.
Moderators or professionals here – what are your thoughts?
