ᐅ How can I arrange IKEA PLATSA furniture in my home office?
Created on: 15 Jan 2022 08:37
Bunu66
Bunu66
15 Jan 2022 08:37
Hello everyone, I am currently planning the setup of my home office and want to use IKEA Platsa furniture for it. My room is about 12 m² (130 sq ft) and has a somewhat unusual shape: one side has a slight slope in the ceiling, and there are two windows on the opposite wall. I mainly want to create storage space for files, books, and technology, but the desk should not feel cramped.
My question is: How can I best arrange the PLATSA series to make optimal use of storage space while creating a comfortable working environment? Are there proven combinations or placements that work particularly well? I would appreciate tips on planning, suitable sizes, and also assembly advice—especially on how to arrange the furniture so the room doesn’t feel too crowded but still offers enough storage. Thank you!
derrick34
15 Jan 2022 09:02
If I were you, I would place the PLATSA cabinets with a shallow depth against the sloped wall – usually, deep shelves don’t fit well there. Then position the desk as close to the window as possible so that daylight comes from the front or the side. This way, you’ll have enough storage space and good lighting for working.
tolokau
15 Jan 2022 09:45
Good morning! For efficient use of IKEA PLATSA furniture in a sloped-ceiling home office, I recommend the following approach:
- First, measure the room dimensions precisely, especially the height under the slope.
- Keep in mind: PLATSA modules come in various depths and heights – use the shallower modules under the slope (e.g., 30 cm deep (12 inches)).
- Below the window, drawer units or lower sideboards are suitable, as they do not block incoming light.
- For the desk, a module with open shelving and space nearby for devices like a printer or router works well.
- Place taller compartments against the flat wall to avoid obstructing the view.
One more tip: If you combine doors and flaps, ensure that none block each other. PLATSA is modular, so you can easily rearrange or add components. If you have exact measurements, I’d be happy to help with the specific assembly.
PECLARISSA
15 Jan 2022 10:34
Hey Bunu66, your project sounds great! 😎 I also equipped my home office with PLATSA and find this series really flexible. I would definitely mix open shelving with closed storage – it creates structure without feeling overwhelming. My tip: use light-colored doors and try to keep an airy look so it doesn’t feel too heavy. And if you can add a small seating area or a plant, it immediately makes the space feel much more inviting.
Rodolfo
16 Jan 2022 07:28
derrick34 schrieb:
If I were you, I would place the shallow PLATSA cabinets against the sloped ceiling – deeper shelves usually don’t fit there.
This approach is efficient. Additionally, I recommend segmenting the storage space:
- Hard-to-reach areas should be reserved for items or devices used rarely.
- Frequently used materials, like notes and electronics, should be placed in the more accessible sections.
- When using PLATSA, take advantage of flexible interior fittings such as shelves or drawers.
It is also useful to consider optional lighting systems inside the cabinets, especially if the sloped ceiling reduces natural light in the area.
jotisi
17 Jan 2022 13:19
PECLARISSA schrieb:
I would definitely mix open shelves with closed storage – it creates structure without feeling overwhelming.
That is certainly a good approach, but I see the risk that open shelves can quickly look cluttered. Especially in a home office where concentration is important, this can be distracting.
Instead, I would suggest keeping the PLATSA units mostly closed and, if needed, designing them attractively—for example, with uniform doors and a consistent color.
Also, I think it’s best not to overdo individual customizations. Minimalism often works better than a mix of wild combinations.
