I have a question that has been on my mind for a while, especially with upcoming moves in view: Has your IKEA Kallax shelving unit ever survived a move completely without damage?
I’m asking in such detail because during my last move, I dealt with various scratches and small dents, even though I handled the shelf fairly carefully. I’m curious whether this might be a general issue—that is, if the unit is prone to damage during moves—or if it’s simply a matter of proper packaging and transport.
I would appreciate hearing about your experiences with safely moving your Kallax, and whether you noticed any particular points to watch out for.
Thanks in advance for your responses!
Hello grazia9,
I completely understand your concern. I also have a Kallax and moved two years ago. To be honest, I took it completely apart – removed the shelves and unscrewed everything – and then carefully padded it with blankets and bubble wrap.
In my experience, that’s exactly the case. The shelving unit itself is sturdy, but if you carry it fully assembled and bump it somewhere, it’s easy to get scratches or dents. That’s why my advice is to disassemble it, secure each board individually, and make sure nothing moves in the middle.
This worked really well for me and the shelf arrived without any damage. If you can’t take it apart, at least protect the corners and edges well, for example with corner protectors or foam.
grazia9 schrieb:
whether it’s simply a matter of proper packaging and transport
I’d like to share my perspective because your topic really resonated with me, grazia9.
I also ended up with some unpleasant marks on my Kallax during my move. That’s naturally frustrating. For me, it wasn’t just about the packaging but also the stress of the move itself – you’re often rushed and not well organized. Next time, I would definitely allow more time and plan better how to transport the furniture.
I also realized that emotionally, it’s not just about a piece of furniture but the feeling you get when you see something you love and have cared for damaged. So now I try not to get too upset if damage does happen but to stay pragmatic 🙂
Maybe this helps you too because you’re not alone when something like this occurs.
grazia9 schrieb:
I’m interested to know if this might be a common issue – meaning prone to damage during moves
Good morning,
to look at the topic from a factual perspective: Kallax shelves are made of medium-density fiberboard (MDF) with a very thin melamine coating. This material is stable enough for normal use but is somewhat sensitive to impacts and mechanical stress.
During a move, the main cause of damage is usually bumping into objects or hard surfaces hitting each other.
My tip based on practical experience:
- Disassemble the shelves to make it easier and safer to transport individual panels
- Protect all parts separately with foam, blankets, or bubble wrap
- Pay special attention to protecting the corners with additional edge guards
- Keep appropriate screws and connectors handy for reassembly
Since Kallax units are relatively affordable and standardized, damaged shelves can be replaced individually if needed. However, this still requires some effort.
In summary: Moving without damage is possible if carried out carefully and in an organized way.
Interesting discussion here. I’d like to ask a somewhat provocative counter-question: How often have you actually managed to get the Kallax out of a move completely undamaged, without even realizing it at first?
That’s an important point I fully agree with. Still, we should also critically consider how much damage is actually caused by unprofessional handling versus the material properties.
The melamine surface is quite prone to scratches, and small marks are almost unavoidable if you don’t pack the shelf individually. But that requires time and space—which are often lacking during moves.
So I ask: Are there products or tricks you’ve used beyond standard padding? Or accessories like frames that protect the shelf? Only in this way can we perhaps achieve better overall results.
Looking forward to your further experiences.
Lisele schrieb:
it’s not just about a piece of furniture emotionally
