Hello dear door specialists,
If I order a glass door with the dimensions 709 x 1972 mm (28 x 78 inches), what size should my door frame be? Should the frame be the same size, 709 x 1972 mm (28 x 78 inches), or does it need to be larger?
I am a bit unsure about this.
Thank you very much for your effort and response,
Beate
Beate
Hello Beate,
The door dimensions are always given based on the outer measurements of the door leaf. Standard doors are usually rebated doors. Since a glass door does not have a rebate, it is referred to as a flush door, which explains the unusual numbers. For your door leaf, a frame with the standard size of 735 x 1985 mm (29 x 78 inches) would be suitable.
Best regards, Marinio
