I am currently renovating my bathroom.
The washbasin and toilet (both from Geberit) are to be integrated into a stud wall system using Knauf profiles. This should not be a problem in principle. However, it is recommended to screw a Knauf UA reinforcement profile to each side of the toilet element. I am wondering if this is necessary when using double drywall (2 x 1.25 mm gypsum boards). Also, the exact purpose of this is not entirely clear to me. The frame of the toilet element already consists of sturdy square steel profiles.
This UA profile is supposed to be screwed to the base channel with angle brackets. At the top, it would only be inserted into the metal channel (UW profile).
Does anyone have experience with this, or is double drywall sufficient to support the tile load?
Hello Ratzec,
Double 12.5 millimeter (1/2 inch) drywall panels improve the surface, but they do not replace structural bracing. The toilet unit transfers loads into the frame and the fastenings. The side UA profiles limit deformation of the installation wall and secure the loads under lateral stress. Knauf and Geberit recommend using UA profiles as flanking elements, anchored at the bottom with floor brackets and firmly connected to the ceiling at the top. Simply inserting them into a thin UW track is not sufficient. In addition, cross braces at the height of the unit, decoupled mounting, and soundproofing strips are required. Tiles do not care about structural integrity. The stiffness of the substructure is what matters. If you want to omit the UA profiles, you need at least double CW studs and a load-bearing sheathing with wood-based panels.
Good luck!
Good luck!
Hello Nauer!
Thank you for the technically clear explanation. The double layer of drywall is already fixed in terms of dimensions. Since the studs will be screwed to the sides of the already stable square profiles of the toilet element, I still don’t understand what additional load they are supposed to support. Since the drywall frame will only be 1.20 meters (4 feet) high, the UA track profile can only connect to a UW track profile. How can it be securely and effectively fastened in this case?
Technically, I still don’t fully understand the purpose, but I don’t want to question your explanation.
What kind of movement or forces are the profiles supposed to absorb exactly?
Hi Ratzec,
The UA profiles do not reinforce the Geberit frame; they stabilize the wall system. You need a load-bearing rectangular frame; otherwise, the entire setup acts like a short cantilever. The test load at the toilet is 4 kN. Without lateral UA profiles and a rigid top connection, the front deforms unnecessarily. The solution for a height of 1.20 meters (4 feet) is: fix the bottom UA with floor brackets and anchors. At the top, avoid a loose insertion into a thin UW profile. Use a continuous UA top beam and anchor it to the structural ceiling or adjacent solid walls via brackets. Alternatively, use a freestanding wall system with tested supports. Double drywall panels improve the surface but do not increase post stiffness. Cross beams should match the element height. Use acoustic sealing tape at all connections. Use impregnated drywall. Keep screw spacing tight.
Hello Nauer!
Thank you for your detailed explanation. This topic has been on my mind for a week now, and I’m trying to find a solution. On one hand, I don’t want to install UA profiles (since I have a very tight installation space and basically no room for them), but on the other hand, I want to do it properly from a technical standpoint. Your thoughts are truly invaluable for this. Unfortunately, Geberit’s support doesn’t offer any assistance on this. I also asked two installers about it. They told me it’s basically not necessary. But that’s a pretty vague statement.
I looked again at Geberit’s documentation, and I noticed that in all installations or assemblies of the pre-wall system that are NOT fastened to the solid wall behind using mounting brackets (at the top), a UA profile is shown. In all other installations where mounting brackets are used, no UA profile is shown.
...maybe I’m just trying to justify myself here—when it comes to safety, I agree with you 100%.
I’m still at work now, but when I get home, I’ll take a photo to show the installation situation.
Thanks again for your input.
