ᐅ Fresh water station and buffer tank: a technically better choice?
Created on: 23 Feb 2020 08:16
freisingerF
freisinger23 Feb 2020 08:16We have now decided on a ground-source heat pump. Two heating installers have offered different technical options:
1. Alpha Innotec heat pump with a 400-liter (105-gallon) domestic hot water storage tank and no buffer tank
2. Alpha Innotec heat pump with a fresh water station and a large 800-liter (210-gallon) buffer tank
Which option is preferable, or how can I evaluate the advantages and disadvantages?
Daniel-Sp23 Feb 2020 09:01Are the 800 liters (approximately 211 gallons) for the heating circuit?
freisinger23 Feb 2020 09:54The 800-liter (210-gallon) tank, as I understand it, is for the heating system, and when fresh water is needed, this warm water is used for domestic hot water production through a heat exchanger/fresh water station. In other words, the water in the tank is not potable water.
freisinger23 Feb 2020 11:19Domski schrieb:
800l buffer tank just for the domestic hot water? How many people do you want to supply?
What kind of flow rate do you need? Well, there are about 6-7 people in the two apartments. The buffer tank is actually just for heating.
Daniel-Sp23 Feb 2020 12:23If you need an 800-liter (210 gallon) heating buffer tank, option 1 is clearly the best choice!
