According to the soil report, we have two options for the foundation.
Option 1: Slab foundation with a 25 cm (10 inches) thick concrete slab and a 80 cm (31 inches) thick bedding layer beneath it. Drainage beneath the bedding layer is not necessary.
Option 2: Concrete slab with strip footings, featuring a 16 cm (6 inches) thick slab. Drainage is not required.
Which of these two options would you choose?
We are completely unsure :-(
Thank you in advance.
Regards, Dali
Regards, Dali
DerBjoern25 Mar 2014 07:59I believe that with option 1, it is easier to install insulation underneath the slab if desired. For our build, option 2 was used. Why? Because that’s what the structural engineer specified...
Bauexperte25 Mar 2014 10:09Hello Dali,
We generally work only with the first option; maybe that helps you.
I don’t really understand the question. Did you buy a piece of a house including the slab, are you planning to build a single-family house and need to outsource the slab work? Or are you awarding the individual trades via an architect’s tender? Do you have professional support? Following that, the further question is: which slab-related services have already been contractually agreed upon? With the options above, don’t forget that option “2” is significantly cheaper, so there is a financial difference compared to option “1.”
Best regards, Bauexperte
Dali schrieb:
According to the soil investigation report, we have the choice between two foundation options.
Option 1: Slab foundation with a 25 cm (10 inches) thick slab, foundation bedding under the slab with a height of 80 cm (31 inches). A bedding drainage can be omitted.
Option 2: Slab foundation with strip footings and a 16 cm (6 inches) thick slab. Drainage is not required.
Which of the two options would you choose?
We are completely at a loss :-(
