ᐅ Single-Family Home Floor Plans Around 160 sqm – What Are Your Experiences?
Created on: 22 Oct 2022 21:01
markusla
My wife and I purchased a plot last year (garden development according to amended zoning plan) marked with number 2018 on the plan, and we now want to move the planning forward. We’re not sure if we will start the construction immediately, but we would at least like to complete the planning phase. The plan is oriented north, meaning the house would be almost aligned north/south.
Zoning Plan / Restrictions
612 sqm (about 6,570 sq ft) + driveway (approx. 85 sqm (915 sq ft))
Slope -> no
Floor area ratio -> 0.3
Site occupancy index -> 0.6
Building envelope, building line, and boundaries -> see drawing (3 m (10 ft) setback, garage allowed on the boundary, max. 15 m (49 ft), of which 9 m (30 ft) continuous) Location of the house on the plot is flexible.
Edge development -> no
Number of parking spaces -> no specification
Number of floors -> 2
Roof type -> minimum pitch 15°, no specific style, but no flat roof
Architectural style -> not specified
Orientation -> no requirement
Maximum height/limits -> max. ridge height 9 m (30 ft)
Special noise protection requirements due to nearby highway and local road
Architectural style, roof shape, building type -> classic detached house, gable roof, solid brick construction
Basement, floors -> basement desired but probably not realistic, 1.5 floors
Number and age of occupants -> currently 3 (ages 32, 28, 1); planning for 3 children’s bedrooms
Room requirements, ground floor and upper floor ->
Ground floor: utility room, kitchen, dining, living, guest toilet with shower, guest room/playroom
Upper floor: master bedroom, 3 children’s rooms, storage room, bathroom
Office: family use or home office? -> both (both adults work from home partly but not full-time)
Overnight guests per year -> negligible
Open or closed layout -> kitchen/dining open and spacious, living room smaller and separate
Conservative or modern style -> conservative
Open kitchen, kitchen island -> open kitchen yes, kitchen island if it fits
Number of dining seats -> 6-8 (extendable table)
Fireplace -> no
Music/sound system wall -> yes if possible
Balcony, roof terrace -> not required
Garage, carport -> combination of both -> car does not need covered parking, but we want a closed space for bikes, workshop, etc.
Garden, greenhouse -> lawn
Other wishes/particulars/daily routine, including reasons why certain things should or should not be ->
- For us, the kitchen/dining area is the central hub, also with guests present. The living room should be a relatively private area.
- Children’s rooms do not need to be very large. The master bedroom is the least important room for us.
- No bathtub required in the bathroom.
- We definitely want a second entrance where the kids (and we) can leave dirty shoes, etc.
- The main entrance is intended for guests.
- The utility/technical room should preferably be outside the main house to save “valuable” living space and expensive square meters. Is this sensible?
- The staircase should not be directly next to the front door. In our current semi-detached house it is, and dirt gets dragged upstairs all the time.
- The floor plan can be designed so that it’s theoretically possible to create two apartments (ground floor and upper floor) in the future.
Who prepared the plan:
- Architect (2nd round)
What do you particularly like? Why? -> We really like the room layout, especially the upper floor is used very efficiently and rooms are evenly distributed
What do you dislike? Why? -> The area around the utility room/side entrance/carport/garage is not ideal yet
Price estimate according to architect/planner: -> rough estimate about $400,000
Personal budget limit for the house, including fittings: $500,000 due to interest rate increase
Preferred heating system: air-to-water heat pump and controlled residential ventilation
If you had to give up anything, which features or fittings
- could you do without: so far nothing, the plan is not very detailed yet
- cannot live without: -
Why is the design as it is now? For example
-> After discussions with the architect about our wishes, the current design emerged. Since securing the plot over a year ago, we have reviewed numerous floor plans online and evaluated their pros and cons.
What is the key question about the floor plan summarized in 130 characters?
Do you have any concrete suggestions for improvement? How wide should the gap between the house and north boundary be, to comfortably park a car and still access the garage?
Thank you very much for your ideas
Slope -> no
Fireplace -> no
Myrna_Loy schrieb:
I can’t remember ever using the main entrance at my grandmother’s house as a child That was probably called the laundry room back then?
Nevertheless, things worked quite differently in those days. It wasn’t just a different time; it is a
Myrna_Loy schrieb:
That’s why I said it depends on how you live. At least today, in 2022. The residential area doesn’t seem to have an agricultural character, and no dog has been mentioned either. And I’d like to point out that even a bathtub isn’t used, so dealing with stubborn dirt on children that needs soaking probably isn’t an issue either. 🙂
Myrna_Loy24 Oct 2022 12:11It was always called a mudroom, or as my grandmother used to say, a boot room. This is still common in new constructions in the USA, usually located near the access from the garage. This also has to do with the fact that entrance halls or large foyers, where clothes and shoes can be stored, are less common.
The idea of having dirty items in the living area is unusual there. With Pinterest and HGTV, this concept is now becoming an inspiration here as well.
Kreisrund24 Oct 2022 14:41Myrna_Loy schrieb:
That has always been called a mudroom, or as my grandmother said, a boot room. This is still common in new homes in the USA, usually connected to the pathway from the garage. It’s also because entrance halls or large foyers, where coats and shoes are stored, are less common there.
The idea of having dirty items in the living area feels strange. With Pinterest and HGTV, this concept is becoming an inspiration over here as well. That’s exactly what I wonder every time I watch those shows. The front door often opens directly into the living space. Where do people keep their coats and shoes? How does that work in everyday life? This might be off-topic here, but I’ve been really curious about it for a while...
I don’t think the entrance area/coat storage is well designed. Where will jackets, shoes, school bags, child car seats, and strollers be stored in winter?
Where do you plan to help the kids put on their shoes and so on?
In the kitchen, workspace would be missing for me.
The living/dining/cooking area feels cramped.
A playroom doesn’t work – at least I have never seen it work.
Where will the laundry be washed? Surely not in the room with shoes, sand, and dirt.
Sand is unavoidable anyway. Imagine how often you’ll need to wash hair after playing with sand in it.
There is a lack of storage space. Especially if you plan for two more children. Clothes, toys, vehicles, strollers, and so on will all be kept, plus Christmas decorations, etc.
There is no bathtub. Have you ever had kids soaked after playing in mud in the fall, or thawed out after sledding? In the contest of who gets the dirtiest, not even underwear stays clean. This Ikea setup won’t last long.
Besides, you’ll want to take a bath yourself at some point. Warm baths can be very soothing.
The open space is gone. Your house will be loud. You don’t want to make it easier for noise to carry throughout the house.
Kreisrund schrieb:
Where do people keep their jackets and shoes? How does that work in everyday life?In wardrobes? … 😉That comes up in almost every floor plan discussion.
