ᐅ Square or rectangular floor plan: are there differences in cost?
Created on: 29 Aug 2012 15:57
fourangelF
fourangel29 Aug 2012 15:57Hello everyone,
since we plan to build next year, I wanted to ask if there is a price difference between a rectangular floor plan (14m x 8m (46ft x 26ft)) and a square floor plan (11m x 10m (36ft x 33ft)). Both would fit on the plot.
Looking forward to your answers.
Best regards, Inge
Best regards, Inge
Bauexperte29 Aug 2012 16:38Hello Inge,
Kind regards
fourangel schrieb:Yes, because 112 sqm (1206 sq ft) living area is more expensive than 110 sqm (1184 sq ft).
... I just wanted to ask if there is a price difference between a rectangular (14 x 8) and a square (11 x 10) floor plan. Both would fit on the plot.
Kind regards
Putting aside the fact that a square is also a type of rectangle, a longer house with the same floor area will have more exterior wall. This, in turn, costs more.
If you compare the exterior dimensions, the longer exterior walls result in slightly less interior space. This means that flooring, underfloor heating, and screed will be somewhat cheaper.
As a layperson, I would assume that the 14x8 (meters) will be more expensive since it already has 2 m² (square meters) more floor area.
14 x 8 = 44 m (meters) of continuous exterior wall
11 x 10 = 42 m (meters) of continuous exterior wall
The interior dimensions are likely approximately:
13.7 x 7.7 = 105.5 m² (square meters)
10.7 x 9.7 = 103.8 m² (square meters)
So, there is both more exterior wall and higher interior finishing costs for the longer-shaped building.
