ᐅ Floor plan: Requesting feedback on the ground floor layout draft
Created on: 25 Apr 2012 21:12
7
7shots
7
7shots
25 Apr 2012 21:12
I would appreciate honest opinions on my floor plan design for the ground floor. Unfortunately, I have never built before and I’m sure I might be overlooking some potential issues. The two openings to the kitchen and living room are planned without doors.
House floor plan: open living/dining area, office, hallway, WC, pantry, stairs.
Boergi
25 Apr 2012 21:54
Hello 7shots,
what I (personally) don’t like:
- The entrance vestibule is quite small and doesn’t feel very inviting. If you have a few people coming or going, you end up cramped.
- In general, I wouldn’t put a door between the vestibule and the hallway, maybe just a larger opening.
- The (guest?) toilet is quite large; if you don’t plan to include a shower, I would make it smaller.
- To get to the pantry, you have to go through the hallway and the vestibule.
- Why is the kitchen door squeezed in there? I would leave it out entirely.
- I also find furnishing the living/dining area difficult. You can’t place a table in the bay window if you still want to use the doors; it doesn’t really fit in the center either. Where would the sofa go? You have a large space that is hard to use efficiently.
- The bay window is quite large—is that intentional?
Sebastian
Der Da26 Apr 2012 07:40
I hope no architect was involved and this was just your first attempt.
Completely remove the vestibule. I don’t see any point in it.
Eliminate the passage to the kitchen; otherwise, you’ll hardly have any storage options in your hallway (shoe cabinet, coat rack, possibly a stroller... and so on).
I would swap the pantry and the toilet.
Try furnishing the living/dining area. You will really run into difficulties.
There are too many windows/doors in the living space. You won’t have any room for bookshelves if that’s desired.
E.Curb
26 Apr 2012 17:23
if you are designing the house yourself, you need to fully furnish the plan and carefully consider whether you really want to go down certain paths (such as having the pantry accessed through the entrance hall).
You should design the entire layout comprehensively. Floor plans and elevations don’t exist in isolation. You need to consider everything together from the very beginning.
This floor plan is likely just a very first idea from you that you will want to discard.
Regards
7
7shots
26 Apr 2012 17:53
Thank you for the constructive feedback. I had already considered the vestibule, but it seemed like the best solution to prevent drafts due to missing doors to the kitchen and living room. In my current version, I omitted the door to the kitchen and added a wide glass door to the living room. This results in a relatively long corridor about 1.80 meters (5 feet 11 inches) wide and approximately 4.5 meters (14 feet 9 inches) from the front door to the glass door. I’m not sure how this will feel in reality.
The guest bathroom is planned to include a shower, which is why it is larger. I have now added some of the furniture, just to give you an idea of my planning. However, I will still need to draw the furniture to scale. The width of the bay window is to ensure there is enough space around my dining table to access the garden/terrace.
I welcome further opinions. Thanks in advance.
Two-dimensional floor plan with staircase and rooms marked in blue
7
7shots
26 Apr 2012 17:55
Apparently, there was an issue with the size of the image. Here is the second attempt:
Floor plan: Dining table with chairs in the center, sofa on the right, kitchen on the left, fireplace.
