ᐅ Floor Construction and Height Adjustment in Renovations (Underfloor Heating)
Created on: 13 Jan 2020 21:04
Arons
Hello dear community,
we have been renovating our house (an old building) for about a year and have created a granny flat. This is completely on the upper floor and extends over the main house (marked in green, see attachment) and an extension (marked in yellow, see attachment). In the yellow-marked extension, there is no screed, only the raw concrete ceiling. In the main house, screed has already been installed. Therefore, there is already a height difference of about 2–4 cm (1–2 inches) between the two areas. In the extension, at the lowest point we have a build-up of 16 cm (6.3 inches) (so the reference line is currently at 116 cm (46 inches)), other points in the extension are at 14 cm (5.5 inches). In the main house, the highest point is at 12 cm (4.7 inches) (reference line at 112 cm (44 inches)).
It is now planned to install underfloor heating in both areas with new screed on top. We are wondering the best way to proceed. Fundamentally, I have two questions: one regarding the height adjustment between the two areas and the other about the general build-up.
[Height adjustment]: Since the floor in the old building is very uneven (partly a difference of 2–3 cm (about 1 inch)), we initially wanted to use a leveling fill to create a flat surface between the extension and the main house. This way, we have a consistent height everywhere.
[Build-up]: We now have about 12 cm (4.7 inches) of floor build-up. The studs plates for the underfloor heating are 32 mm (1.3 inches), plus screed and the floor covering. We will probably install vinyl flooring, but we still need to determine the thickness. In any case, something needs to be installed under the studs plates of the underfloor heating so that we reach the required 12 cm (4.7 inches). In the extension, we planned to place EPS (expanded polystyrene) on the leveling fill and then the studs plates (which also have about 10 mm (0.4 inches) of insulation). The EPS panels also make it easier to walk on during the installation of the underfloor heating than directly on the leveling fill.
For the main house, we have two options. Either we also place EPS panels on the old screed and then the underfloor heating, or we put the underfloor heating directly on the old screed, which would require a thicker screed layer.
[Summary]:
1. Is the leveling fill (e.g., Fermacell) suitable for height adjustment?
2. Can we lay EPS panels under the studs plates of the underfloor heating in the extension? Which panels are recommended or what should be considered? I recall that only one type of insulation or only one layer of impact sound insulation is allowed under the underfloor heating (to avoid compressibility issues). The studs plates themselves also have a type of insulation. Which EPS panels (or something completely different) can we use here?
3. Should we also place EPS panels under the underfloor heating in the main house or is it better to use more screed?
We are under some time pressure, which might influence the options (e.g., more screed takes much longer to dry). But regarding the screed, I will start a separate thread anyway. Time pressure or not, it should be done properly.
Also, since the granny flat is located on the upper floor, our main house is underneath. Therefore, better to have somewhat more (impact) sound insulation than too little.
Thank you very much!
Floor plan of a residential building with kitchen, bathroom, hallway, living room, bedroom, and children’s room as well as balcony.
Dr Hix15 Jan 2020 11:52
I have to admit, I can’t give you a definitive and well-founded answer on this. My insulation supplier and screed installer also recommended using two layers whenever possible (which makes sense because it allows you to overlap the joints), with only one layer being impact sound insulation (DES).
Your dimpled sheets actually have EPS DEO attached. So, you can place the maximum possible thickness of EPS DES impact sound insulation underneath.
kaho67416 Jan 2020 13:14
I would like to briefly join this thread, as our question is along the same lines.
In our older building, we also have an uneven floor with wooden ceiling joists. We want to level it using a leveling compound and then install panels on top, which will be finished with tiles or laminate flooring. The heating system is not installed in the floor.
Now the question: Are there any specific materials to maximize fire resistance? We plan to rent out the property and want to minimize the fire risk.
Dr Hix16 Jan 2020 13:17
Perlite should be suitable for this, although it generally requires a minimum installation thickness of around 30mm (1.2 inches).
kaho67416 Jan 2020 13:20
We have no issues with the height; the rooms are over 4m (13 feet) high.
Perlite is noted.
Dr Hix16 Jan 2020 13:34
In this case, it might be worth considering additional impact sound insulation made of stone wool. Or do you not live below?
Vicky Pedia16 Jan 2020 13:48
Dr Hix schrieb:
In this case, maybe also consider adding a stone wool impact sound insulation. Or do you not live underneath?
I would like to cautiously point out that stone wool is not impact-resistant. But oerlite alone at this build-up height already makes a big difference.
