ᐅ Exterior insulation with rhombus cladding for rain protection
Created on: 25 May 2020 17:19
joshia01Hello,
I need to renovate an exterior wall. It’s the weather-exposed side and the plaster has fine cracks, with some plaster already coming off, especially around the roller shutter box (two different materials there). I see a ventilated cladding with rhombus-shaped battens as the most cost-effective option. I’m also considering fiber cement panels (honestly, I like them better and they seem easier to install), but they are quite expensive. The area is about 60m² (645 sq ft), excluding 3 windows and a patio door.
I want to cover the exterior wall with planed, natural-colored Siberian larch rhombus battens. Since I plan to leave a joint gap of 8-10mm (0.3-0.4 inches), I’ll need to protect the wall behind from driving rain. For that, I intend to staple a breathable membrane to the wall. This membrane will then be supported by the counter battens.
Is this a suitable approach, or could it cause moisture problems?
The proposed assembly would be:
- breathable membrane
- counter battens
- rhombus-shaped battens
Thank you and best regards,
Jörg
- counter battens
Jörg
nordanney25 May 2020 18:18joshia01 schrieb:
Is it possible to do it like this?No, you have forgotten the insulation, which you are required to include. Or is this about a newer insulated facade or a listed (heritage) facade? How are you currently protecting the facade against driving rain?Similar topics
