I have an IKEA KALLAX shelving unit that I would like to reinforce along the edges afterwards. I am particularly interested in which materials have proven effective, the best methods for applying them, and whether this significantly improves stability. My main concern is the load-bearing capacity of the shelf edges under increased use, for example when placing heavy boxes or electronic devices. Does anyone have experience with retrofitting edge reinforcement on a KALLAX? Tips on appearance and potential pitfalls during installation would also be appreciated.
Thanks in advance!
Thanks in advance!
For retrofitting edge reinforcement on the KALLAX, I recommend aluminum angles or steel profiles with a width of about 15-20 mm (0.6-0.8 inches). These should be installed using countersunk screws and pre-drilled holes to protect the panel material. Alternatively, PU adhesive combined with edge strips can be used, although this provides less additional stability.
The choice of material depends on the expected load: plastic profiles are sufficient for light to moderate loads, while metal profiles are preferable for heavy loads.
Dwight49 schrieb:
The choice of material depends on the intended load: For light to medium loads, plastic profiles are sufficient; for heavy loads, metal profiles are preferable.I fully agree with this. Additionally, I recommend high-quality screws with an appropriate diameter, not too long—about 10-12 mm (0.4-0.5 inches) is sufficient. Plastic PVC edge trim elements increase impact resistance but contribute less to load-bearing capacity. Metal is the preferred choice for high stress applications.
BELLA34 schrieb:
I used thin metal profiles and fastened them with small screws. It holds well and looks neat.Thanks for the tip, bella34! Do you think screwing at the front edge affects the appearance of the furniture? I would prefer the screw heads not to be visible.
PERON schrieb:
I reinforced my KALLAX edges with self-adhesive aluminum strips.Are there any issues with adhesion on the melamine-coated surface when using self-adhesive strips? Or does it usually hold up permanently?
