ᐅ Experiences with Retrofitting Edge Reinforcement on KALLAX?
Created on: 23 Nov 2016 20:17
mabosin
I have an IKEA KALLAX shelving unit that I would like to reinforce along the edges afterwards. I am particularly interested in which materials have proven effective, the best methods for applying them, and whether this significantly improves stability. My main concern is the load-bearing capacity of the shelf edges under increased use, for example when placing heavy boxes or electronic devices. Does anyone have experience with retrofitting edge reinforcement on a KALLAX? Tips on appearance and potential pitfalls during installation would also be appreciated.
Thanks in advance!
LEOPAU
24 Nov 2016 12:02
Basically, a good question regarding the look when countersinking screws: if you don’t want the screw heads to be visible, you should use countersunk screws and then fill the holes with wood filler or color-matched plastic caps.
Regarding the durability of self-adhesive aluminum strips on KALLAX, the melamine-coated surface is usually smooth enough for high-quality two-component adhesive to provide good bonding. It is important to thoroughly clean the contact points before gluing (free of dust and grease).
One more note on stability: metal strips should cover the corners and especially the front edges, as these areas experience the most stress.
EDWARD0
24 Nov 2016 15:39
I worked similarly to BELLA34 and can confirm that pre-drilled holes with countersunk screws plus filling is a clean solution. Stability increases significantly, especially for shelves with higher loads. Self-adhesive solutions are more of a protective measure against edge damage, not primarily for load-bearing purposes.
mabosin
25 Nov 2016 08:23
LEOPAU schrieb:
It is important to thoroughly clean the contact surfaces before bonding (free of dust and grease).
Thank you for the tip! Which cleaning agents are best suited without damaging the melamine surface? For example, does regular dish soap cause any harm, or is isopropanol better?
EDWARD0 schrieb:
Self-adhesive solutions are more of a protective measure against edge damage, not primarily intended as load-bearing elements.
That is a good point, which I hadn’t considered enough in my planning so far.
Jan31
25 Nov 2016 10:41
For cleaning before bonding, I always use a lint-free cloth with some isopropanol. Dish soap can leave residues, so it is better to avoid it when dealing with adhesive surfaces.
