ᐅ Experiences with Ground Source Heat Pumps
Created on: 23 Oct 2015 21:40
Saruss
here I would like to share some experiences and data regarding my brine heat pump and deep drilling, based in part on the expert’s "questionnaire":
a) What is the soil composition on your property?
Up to 3m (10 feet) silty, fine sandy, clayey soil
Up to 4m (13 feet) slope debris, rock fragments
Then bedrock (mainly limestone)
b) How deep was the drilling?
Drilled twice to a depth of 72m (236 feet)
c) How much did the drilling cost?
€10,400 including double U-probes DN25
Grouting material with 2.0 W/mK thermal conductivity
Permitting process (building permit / planning permission)
Pressure-tight house entry at the basement and underground routing of supply lines (about 25m (82 feet))
Filling/draining equipment, filling, pressure testing, etc. (all inclusive)
d) How much did the system cost?
System: Tecalor TTc 05 with heating output at B0/W35 of 5.8 kW and coefficient of performance (COP) of 4.8
Cost: €9,800
e) Were there any difficulties during installation, if so, what kind?
Because the water used to flush out the drilled material during drilling seeped away, a "small compressor" was needed to blow it out with air. However, it had to be placed on a neighbor’s property who had not yet started building. The machine was the size and approximate weight of a 20-ton truck but was off-road capable. This caused a 2-day delay because the compressor first had to be transported to our site. No additional costs were charged.
f) How is the daily operation?
"Like a refrigerator." Once the parameters on the heating system are correctly set, the only thing that should be done is occasionally reading the information/data such as operating hours and source temperature. Otherwise, it runs "on its own," just like any heating system. When the door is closed, the unit is virtually inaudible. Very discreet since, apart from the cabinet in the utility room, nothing else is visible (all brine pipes are underground).
e) What are the operating costs for which living area?
Currently, a living area of 180sqm (1937 sqft) is heated, plus an additional 65sqm (700 sqft) of cellar space within the insulated thermal envelope (these rooms are around 15-16°C (59-61°F) on the coldest days). From September 2014 to September 2015, 2,000 kWh of electricity was consumed for heating and hot water (2 adults, 1 baby, 1 toddler). The house is a KfW-70 standard building according to the 2009 energy saving regulations, which already met the required technical standards before the central ventilation system with enthalpy heat exchanger was installed (we decided to add this after the initial applications).
f) to be continued ....
Note regarding the comparison of the coefficient of performance (COP):
Since optimizing the heating curve and settings at the end of last year, the system has had a COP of about 5.5. Operating hours are around 1200; the deep borehole was drilled approximately 20% deeper than initially recommended by the companies, at our own request.
Saruss
31 Dec 2015 18:01
BeHaElJa schrieb:
I have the passwords and such – I could change settings too, but I’d rather not (might break something and void the warranty).
Does your brine outlet temperature never drop to +2°C (36°F)? What heating demand do you have at what drill meter depth (and what extraction capacity does your ground have)?
Isn’t the COP usually given at 0°C (32°F) brine inlet temperature?
My data is on page 1. My minimum goes into the negative range. Last winter, after long cycles, the outlet was 5°C (41°F). It wasn’t really that cold, but still much colder than it has been this year so far. COP is usually given as 0°C (32°F)/35°C (95°F) for ground source heat pumps. Usually, the inlet temperature is higher and the supply temperature lower; detailed charts in the manual show how the COP behaves under these conditions.
MeisterBob
31 Dec 2015 18:05
Yes, there are two buffer tanks in the boiler room. So far, only two people live here, both working full-time. The energy consumption is approximately 900 kWh during peak hours and 900 kWh during off-peak hours, totaling 1800 kWh.
Sebastian79
31 Dec 2015 18:10
Do you have a heat meter?
MeisterBob
31 Dec 2015 18:15
Yes, what would you like to know?
Sebastian79
31 Dec 2015 18:26
Yes, the amount of heat generated, otherwise this all has little significance and comparing becomes more difficult.
Legurit
31 Dec 2015 18:28
Then I will have the source checked again. We specifically ordered additional meters (2x70). However, the acceptance test was actually fine so far – on May 2nd.
