ᐅ Door on FAKTUM IKEA wall cabinet does not stay open, installation aid
Created on: 10 Apr 2010 11:11
1
16nullzwo
1
16nullzwo
10 Apr 2010 11:11
I bought three Faktum wall cabinets for the kitchen. The doors open upwards horizontally, but they do not stay open. What do I need to adjust on the hinges to keep the doors open and prevent them from immediately falling back down?
Thanks for your help
andre1971
14 Apr 2010 12:38
Hi,
do you still have the installation manual? It’s described there.
If you remove the white cover from the hinge, you will find a hole where you can adjust the door’s weight using a screwdriver.
Regards, andré
jamaha
4 Jan 2012 16:39
Hello dear helpers,
I have the same problem. However, I have already set the weight to the maximum. What else can I do?
The door holds at the top on a wooden door, right?
Thank you for your reply
IKEA-Experte
5 Jan 2012 13:57
On the website of blum (--> Aventos HK) there is also a video about it. If it is already properly adjusted to the maximum limit on both sides and the door does not stay closed, then a door lifter might be broken.
jamaha
9 Jan 2012 13:13
Thank you,
I just tried to force it and, lo and behold, it went further.
The screws were so tight, it was as if they had been glued.
Thanks for your help,
