Hello everyone, we are planning to get a garden shed this year. Since we still have over 200 roof tiles left from building our house, we are considering covering the garden shed roof with these tiles. What should we keep in mind? Do you have any experience with this? We are thinking of a garden shed measuring 3.33 x 3.10 meters (11 x 10 feet). The side walls are 28 mm (1.1 inches) thick. I don’t know the roof pitch yet, but it is very shallow (according to the catalog image). It is a gable roof. What needs to be considered here?
The roof will certainly need to be reinforced. How can this be done?
The rafters are also important, with a minimum size of 6x14 cm (2.4x5.5 inches), preferably 6x20 cm (2.4x7.9 inches), and the rafter spacing should be about 65 to 80 cm (26 to 31.5 inches).
The roof pitch is crucial to prevent water or snow from getting under the roof tile.
Here is a small guide:
Double S tiles by Braas from 22 degrees (°C) (72°F)
Saphir Kartago – manufacturer Braas – from 22 degrees (°C) (72°F)
Granat 11V – manufacturer Braas – from 25 degrees (°C) (77°F)
Achat 10 V – manufacturer Braas – from 22 degrees (°C) (72°F)
Ergoldsbacher E58 SL – manufacturer Erlus AG – from 20 degrees (°C) (68°F)
Ergoldsbacher Großfalzziegel – manufacturer Erlus AG – from 28 degrees (°C) (82°F)
Rapido Falzziegel – manufacturer Creaton AG – from 16 degrees (°C) (61°F)
Terra Optima – manufacturer Creaton AG – from 18 degrees (°C) (64°F)
Check the back of the roof tile... the manufacturer and the name of the tile are printed there.
caspar.1 schrieb:
It is also important that the rafters are at least 6x14 cm (2.4x5.5 inches), preferably 6x20 cm (2.4x7.9 inches), with a rafter spacing of about 65 to 80 cm (25.6 to 31.5 inches).
The roof pitch is crucial to prevent water or snow from getting under the tiles. You are really overdoing it with the rafters. For a static rafter length of 1.8 m (5.9 ft), roof trusses made from boards are more advisable here.
I have checked our roof tiles. They are Braas Rubin 13V. The manufacturer specifies a minimum roof pitch of 16 degrees for these. The garden house we are interested in has a roof pitch of 19 degrees, so that should be fine.
I was thinking of reinforcing the garden house initially against unfolding like a shoebox by using a crisscross metal strap. I planned to support the main roof beam from below.
So, would you replace the individual rafters and also space them closer together?
Powermichi30 Aug 2021 22:54Hello tx 25, how did you proceed? How did you reinforce the roof? And how is it holding up?
Best regards, Micha
Best regards, Micha
