can someone roughly tell me how much a clinker brick slip facade might cost? Or if it is much more expensive than a paint finish?
In our region, you hardly ever find facades like this.
guckuck2 schrieb:
Of course, there is [...] sand-lime brick, insulation, air gap, sand-lime brick. On top of that, depending on preference, plaster with facing bricks as an accent. Exactly, I told you: plaster or facing bricks on stone. The facing bricks here are applied on the second layer; they wouldn’t work well as the second layer themselves.
Kekse schrieb:
In this area, the common construction method is to build plastered houses mostly with a cavity wall. A second layer is not always just for appearance, and the same applies to plaster as I described earlier: it requires a stable base. Plaster can be applied on foam insulation boards, but when using fiber insulation boards, the plaster needs a masonry layer as a base.
