ᐅ Corners of the new windows are very poorly finished or scratched
Created on: 22 Jun 2018 18:49
cybergnom
this week our windows were installed. Unfortunately, all the corners of the windows look quite damaged, as if the corners were dragged across the floor. See the photos.
Since this is the case with all the windows, I assume it is a production issue.
I have already informed my window installer and expect to receive a response on Monday.
For my own "preparation":
1. Is this considered normal and something I would have to accept if necessary?
2. Is there any way to repair this?
Close-up of a white furniture edge with a gap and damaged corner
White furniture front corner with edge, metal plate and screws, orange baseboard visible
White wall panel at the corner with joints in interior finishing
Mycraft25 Jun 2018 09:33
Amateur opinion, as expected... the general contractor/window installer will not replace anything. You might as well stand on your head.
Unless, of course, they want to avoid further hassle and money is no object.
Schwimmbutz
25 Jun 2018 09:39
I understand that the corners of the windows are always polished. However, in my opinion, this has been done very untidily here. Maybe I am just used to "better" windows and workmanship...
Mycraft25 Jun 2018 09:44
Oh, look at that. It is well known that this is completely normal.
You shouldn’t have to tolerate it, but replacing is probably like using a cannon to kill a sparrow.
It just looks like no follow-up work was done. However, the window manufacturer can fix this afterwards with solvent or even simple sandpaper.
nordanney
25 Jun 2018 15:01
Mycraft schrieb:
Oh, look at that. It’s well known that this is absolutely normal.
If this appearance and quality are normal and you were a tradesperson, you would have had to declare bankruptcy many years ago ;-)
Alex85
25 Jun 2018 15:13
I also don’t see what is supposed to be normal about that?!
Mycraft25 Jun 2018 15:20
It is normal for rework to be done, which apparently has NOT happened here yet. The ridge was only machined down after welding, and it seems the machine was not very precise.
However, this is not a problem. You just need to address it, and someone will come to fix the edge so that nothing is visible anymore.
Making a mountain out of a molehill... making a mountain out of a molehill...
P.S. I actually wanted to comment after the first reply, but I held back because I thought someone knowledgeable would respond.
Unfortunately, that didn’t happen, so I decided to write after all.
@cybergnom
Have the window installer come back and rework the corners. Half an hour of work. Issue resolved.
