I have been considering converting an IKEA Kallax shelf into a craft table because I need a compact and affordable solution for my small workshop. The idea is to lay the shelf on its side and add a sturdy worktop to achieve a comfortable working height. However, I now wonder if there are any stability issues with such a conversion or when using it as a worktable, especially when applying more force, for example when cutting, gluing, or assembling.
Does anyone have practical experience with a converted Kallax as a craft table? How stable is the shelf under load, and what measures would you recommend to improve its stability and sturdiness? Are reinforcements necessary, or is the basic construction sufficient? I would appreciate your assessments and tips!
Basically, the Kallax shelf is not designed to withstand side loads. This means stability issues can occur, especially when pressure is applied from above or from the side.
I would recommend reinforcing the shelf at the back with sturdy cross braces or building an alternative substructure. This will prevent tipping and twisting movements.
Hello LOSAN43,
I find your question very interesting because the idea of using a Kallax unit as a craft table is indeed a practical and space-saving solution, but it also presents some technical challenges.
The Kallax system is structurally designed to carry vertical loads in a shelving or storage function. When you lay the unit on its side and use it as a tabletop, the forces act very differently – mainly involving compressive and shear stresses across the wood grain and joints.
This usually causes the unit to bend or tip under too much load because the side panels are not stiff enough. Additionally, twisting often occurs since the connections between parts – usually glued and only fitted together – were not originally designed for this load direction.
In practice, I recommend first checking whether your tabletop itself is stable enough. Then you should reinforce the back or sides with additional braces or brackets. For example, you can screw metal brackets under the tabletop that are fixed to the sides of the unit, which prevents it from bending upwards.
Another option is diagonal or cross braces on the back, which significantly increase torsional stiffness.
One more tip: Make sure to pre-drill all screw holes carefully and tighten the fasteners firmly, as loose connections can substantially reduce stability.
I’m also curious about the size of your tabletop and the material you plan to use, so I can offer more specific advice – use the actual dimensions, as larger surfaces place greater stress on the Kallax unit.
Best regards!
Best regards!
Dilen schrieb:
The Kallax system is structurally designed for vertical loads in shelf or storage functions.That’s a great explanation! 🙂 I once converted a Kallax myself and can confirm: without additional reinforcements, the shelf really starts to wobble quickly under load.
For my conversion, I used small brackets and fairly thick plywood panels as a back panel. This made the system sturdy enough for all my DIY projects, even when I sometimes had to apply a bit more force.
It’s also important to place the table on a level floor—uneven surfaces increase the “tilt” feeling! Additionally, I attached felt pads under the feet; these can help prevent scratches and make the whole setup a bit more stable.
All in all: go for it, the conversion is worth it, but plan for some extra material for reinforcements. Good luck with your project!
