ᐅ Connecting an LED ceiling light – multiple wires hanging from the ceiling
Created on: 5 May 2021 15:42
Handwerkerin
Hello
I need some help again.
After decades without a ceiling light, I have now bought an LED ceiling fixture (metal and plastic).
Open ceiling wiring with gray, green, black, brown wires and connectors.
This can be turned on and off or dimmed using a remote control.
The original light switch is probably no longer needed.
But now my question.
The building was constructed in 1963. Several cables are hanging from the ceiling. 😳 I don’t know which ones need to be connected to the fixture.
I’m attaching two photos for clarification.
Thank you in advance for any helpful answers.
PS: Of course, I will switch off the circuit breaker beforehand 🙂
Connection image: L-, N- and ground wires on a terminal strip.
HausiKlausi5 May 2021 22:04
As far as I’m concerned, the pragmatist should come, not the electrician. The question only suggested that basic knowledge was missing. And I’ll repeat once more: If it’s a lamp with a metal housing and the old wiring described above, which has no separate grounding, there are situations where it’s not the lamp that lights up, but the person trying to screw in a light bulb.
Tarnari5 May 2021 22:48
I do a lot myself, but I have a great deal of respect for electrical work...
Handwerkerin
5 May 2021 23:10
Thank you very much for all the replies. I will keep you posted 🙂
Stefan001
6 May 2021 14:42
If you still can...
A local doctor recently died after touching a live door in his practice, likely due to faulty work by an electrician during the connection. (One of the arriving firefighters also had to be resuscitated. Eight children behind a second live door were warned just in time!)
Tarnari6 May 2021 16:47
Since I read about it in the media, I’ve been looking at our motorized lock in a completely different way... ^^
Handwerkerin
6 May 2021 23:29
Thank you for the reply and the warning 🙂
