ᐅ Any experiences with purchasing batteries with more than 1 kWh capacity?
Created on: 29 Sep 2022 22:07
Frosist
we are considering using batteries instead of a generator to be prepared for possible power outages. However, all devices with more than 1 kWh capacity quickly cost a thousand euros or more. The question is whether it is worth it. If the grid ever fails, the investment would probably be worth the cost?!
Regards
Regards
WilderSueden29 Sep 2022 23:29This is not about making a prediction. It's about whether the sizing matches the scenario. A 3-day power outage and a 5 kWh battery do not fit together; you need to go much bigger.
I would rather use camping equipment (stove, lamps, propane infrared heaters) than spend so much money on batteries that I hardly ever need. It’s much cheaper per €/kWh. Plus, boiling water is easier and more practical with gas than with electricity. Ideally, you have a caravan – they also have gas-powered refrigerators, but that will be a minor issue in winter if there’s no power supply.
Otherwise, a portable photovoltaic system, a suitable charger, and an e-bike battery that isn’t locked to a specific brand or device. You can connect anything up to 36V, or use an inverter for 220V appliances if needed.
