Created on: 27 May 2019 10:48
goalkeeper
Mike29
15 Apr 2020 21:06
Unfortunately, you are mistaken. This is the Premium Black Steel, at least that’s what the delivery note says. The model number is the same as the one you posted earlier, RS6GN8321B1/EG. It’s more of a dark anthracite color, which can also be seen in Samsung’s product images where the water dispenser is shown on a "true" black front panel.
But you are right about the fingerprints; they are not visible.
15 Apr 2020 21:29
It looks great!
Mike29 schrieb:
a sheet metal tray also fits in the cooling compartment,
How does that work? Across?
Would it be too much to ask *clears throat* if you could measure a shelf? *Tinkling with my hazel eyes*
Mike29
15 Apr 2020 22:22
So ours fits in, a standard baking tray.
Dimensions: 46cm (18 inches) wide and about 46cm (18 inches) deep for the shelves.
Now here’s the catch I noticed when measuring:
It depends on the height at which the shelves and door compartments are installed. In our case, the shelves are positioned so that the baking tray can fit lengthwise inside the door. This results in a depth of over 50cm (20 inches).
The tray also fits crosswise, as shown in the attached image for those interested, but only by inserting it diagonally.
Open freezer compartment with yogurt cups, bottle and egg carton; display shows -18°C (0°F).
15 Apr 2020 22:42
Mike29 schrieb:
So ours fits, a standard baking tray.
Now comes the but, which I noticed when measuring:
It depends on the height at which the shelves and door compartments are installed. With us, the shelves are positioned so that the baking tray can fit lengthwise in the door. This results in a depth of over 50cm (20 inches).
The tray also fits crosswise, I attached something for the brown eyes to look at, but only by inserting the tray diagonally.
Oh yes... I actually meant the freezer. There are things you should freeze individually on a tray.
Now I got the idea that I also have a small tray and could transfer food if needed. Thanks for the nudge of inspiration.
Fummelbrett!
16 Apr 2020 08:45
Oh, I actually meant the freezer. There are items that should be frozen individually on a tray.
But now I’ve got the idea that I also have a small tray and could transfer the food if necessary. Thanks for the thought-provoking tip.
If you just want to freeze food, I can recommend shallow GN stainless steel containers. They come in various sizes and the food freezes incredibly quickly inside them. For example, when I freeze berries, including raspberries, I can easily stack them loosely in a deep GN container with a lid. Once frozen, they don’t stick together and can be transferred directly loose into a bag. I also pipe cream dollops into shallow containers, and they freeze in no time.
Mike29
16 Apr 2020 09:34
You can of course use GN containers for this. If they are too expensive or you don’t specifically need GN sizes, stainless steel containers from the Swedish store also work. Their dimensions are slightly different from GN, but they cost only a fraction. I use them for grilling, and my wife uses them for cooking.
