ᐅ Missing BILLY Shelf Screws: What Can I Use as a Replacement?
Created on: 6 Jun 2020 08:32
ANKAR50
I just assembled a Billy bookshelf from IKEA, but when I got to the screws pack, important screws were missing—especially the wood screws for the back panel and some connector screws. My question is: What can I use as replacements for the missing screws without compromising the stability and safety of the bookshelf? Is there an alternative with similar strength that holds well in wood? I’m considering using common household screws or something else, but I don’t want to take any risks, and of course, I want the bookshelf to look neat. Thanks in advance for your advice!
kulau
6 Jun 2020 12:00
ANKAR50 schrieb:
I have some concerns about the exact thread type because I don’t want to risk damaging the material.
That’s a valid concern. IKEA Billy usually uses chipboard screws with coarse threads, which are specifically designed for wood-based materials. These are quite different from machine screws, which have fine threads and are intended for metal.
Typically, the screw diameter is M4 (4 mm (0.16 inches) outer diameter) for connecting joints. The length should not exceed 25 mm or 30 mm (1 to 1.2 inches), depending on the thickness of the wood being joined. For thinner back panel screws, lengths of around 15 mm (0.6 inches) are common.
You can measure the existing screws, if you still have any, with a small wrench or a similar tool. If you don’t have any left, your local hardware store or specialist supplier can also provide sample screws to compare.
It’s important that replacement screws have a full thread to securely hold the shelf together; otherwise, the assembly won’t be stable. When replacing back panel nails, I recommend using thinner, flat nails or special panel clips. These won’t split the wood and still provide a secure hold.
boelnu
6 Jun 2020 14:44
I can easily understand how frustrating it is when you’re missing important screws during assembly. I’ve been there too. For me, it was crucial to use something that really fits, because otherwise the entire shelf would wobble or eventually fall apart – that would have been really stressful.
kulau schrieb:
It is important that the replacement screws have a full thread
I completely agree. The first time I tried, I used different screws, but they were too thick and split the wood, which was obviously counterproductive. So it’s better to rely on the right screws from the hardware store.
If you can’t find screws that fit exactly, it’s better to take a step back and wait for a proper delivery or order online exactly the screws IKEA tends to include. Sometimes safety is more important than speed.
GU-LAU60
6 Jun 2020 16:17
Replacement for BILLY shelf screws: best to use chipboard screws M4 x 25mm (1 inch). For the back panel: thin nails about 15mm (0.6 inches) long or suitable back panel clips. Always fits perfectly for me.
dijan
7 Jun 2020 07:45
LAYNE schrieb:
Chipboard screws are basically the all-rounders in the world of furniture screws 😄
I completely agree! And if you want to improve the appearance of the shelf, you can even cover the screw heads with small caps, which are available at hardware stores. This way, it’s not noticeable that you used replacements – plus the stability remains intact. 🙂
janfo
7 Jun 2020 10:03
ANKAR50 schrieb:
Are there typical specifications to identify which replacement screw will really fit?
Measuring is the most important step. Diameter M4, length 25mm (1 inch) – that usually works well. For the back panel, use nails about 15mm (0.6 inches) long.
kulau
7 Jun 2020 14:25
One small tip: When buying replacement screws, also pay attention to the screw head. IKEA often uses countersunk screws, which sit flush with the surface during assembly. If you use replacements with a head that is too large or too small, it can look untidy later or cause problems when screwing in.
In general, chrome-plated or galvanized screws are good because they are corrosion-resistant. For the interior parts of the shelf, this is often not so critical, but it doesn’t hurt.
If you’re unsure which screws are missing, you can also check the IKEA assembly manual for part numbers and compare the parts there with their descriptions.
