ᐅ Installing a BILLY Shelf with Wall Anchors – Which Type for Which Wall?
Created on: 27 Aug 2021 08:37
RIROKE
RIROKE
27 Aug 2021 08:37
I am currently planning to install my BILLY shelf and want to secure it safely to the wall. My specific question is: Which types of wall anchors are suitable for which wall materials when mounting a BILLY shelf? I have options including bare brick walls, drywall (also known as plasterboard), and concrete walls. Naturally, I want to avoid anchors that won’t hold properly or that are oversized.
If experienced installers could share their recommendations on which anchors provide the best stability for different wall materials, that would be very helpful. I’m also interested to know if there are any specific anchors recommended for the BILLY shelf, or if standard universal wall anchors are sufficient.
Thanks in advance for your advice!
JEREMIAH38
27 Aug 2021 09:12
Hello RIROKE,
I understand exactly how confusing it can be to choose the right wall anchors – about a year ago, I faced a similar task and wasn’t sure which manufacturer’s anchors would be best for my walls.
RIROKE schrieb:
"Which types of wall anchors are suitable for which types of walls when installing a BILLY shelf?"
For unplastered brick walls, I recommend expansion anchors, which expand and secure themselves where they are screwed in. This provides a good hold. For drywall, it often depends on the sheathing and the cavity behind it. In these cases, cavity anchors or metal toggle anchors are advisable because they open behind the board, creating a larger surface area for support. Concrete ceilings or walls are best secured with universal or multipurpose anchors that are anchored deeply.
I know that during my first installation, I was worried the shelf might simply fall if the anchors were too weak. 🙂 But with the right anchors, the BILLY shelf holds really well on the wall. Hope this helps you!
bensau
27 Aug 2021 11:53
I’d like to casually add that the choice of anchors also depends on the load from the shelf. Especially if you fill the BILLY with books, it will get quite heavy! 😅
For heavy loads on drywall, I would definitely recommend metal anchors with a toggle or wing design. They don’t pull out as easily and distribute the load better.
JEREMIAH38 schrieb:
"With drywall, it often depends on the cladding and the cavities behind it."
That’s very important to keep in mind because just pushing an anchor into the surface can end badly.
My tip: Before drilling, gently tap the wall with a hammer — hollow sounding spots are critical!
Good luck with your screws, and don’t worry, it will definitely work out! 🙂
Surela
28 Aug 2021 07:44
Good morning,
to thoroughly cover the topic of wall plugs for the BILLY shelf, here are some technical details that are often underestimated:
1. Brick walls:
For unplastered brick, I recommend nylon expansion anchors that expand significantly when screwed in. It is important to choose the drill hole size precisely (usually 6–8 mm (0.24–0.31 inches), depending on the anchor) and to carefully clean the hole from dust before screwing in. A dirty hole greatly reduces holding strength.
2. Drywall (plasterboard) walls:
Key factors here are the thickness of the board and the cavity behind it. For 12.5 mm (0.5 inches) boards, I usually use metal toggle anchors (metal snap toggles). These can be securely screwed in and distribute the load over a larger area behind the board. Please note that there are also special heavy-duty anchors for drywall, which are recommended for higher loads (e.g., for fully loaded BILLY shelves).
3. Concrete walls:
For concrete, heavy-duty anchors or bolt anchors offer the best stability. Universal plastic anchors with a screw are often sufficient for moderate loads, but for shelves carrying a lot of weight, I would recommend metal expansion anchors.
4. General:
For BILLY shelves, manufacturers often recommend using the supplied anchors, which are usually nylon expansion anchors. These are fine if the wall allows it and the load is not too high. For greater safety or special wall types, I opt for specialized anchoring systems.
A quick question for RIROKE: What exactly is the material of your wall, and what load do you plan? That could allow for more specific advice.
RIROKE
28 Aug 2021 12:17
Surela schrieb:
"Quick question for RIROKE: What exactly is the material of your wall, and what kind of load are you planning?"
Thank you for the detailed explanation, Surela! My main wall is an unplastered brick wall, which I want to firmly attach the BILLY shelf to. The second wall, where I might install an extension, is a drywall (plasterboard) wall—I plan to fill the shelf with books, so it will carry a considerable load. Therefore, I am a bit concerned whether the standard shelf anchors will be sufficient for the load-bearing capacity, especially on the drywall side.
Do you have any specific recommendations for anchors available at common hardware stores, without needing to buy from specialty suppliers? And is it advisable to use additional reinforcements on the drywall side, or would it be better to screw directly into the studs behind the drywall?
Lotizar
29 Aug 2021 14:26
Hello RIROKE,
based on your explanations, here is a summary of the key points:
For unplastered brick walls, nylon expansion anchors with the appropriate diameter (usually 6 or 8 mm) are the best choice. They hold securely and are easy to install. Important: drill very straight and clean the holes thoroughly.
A clear recommendation for drywall (plasterboard) walls: if possible, screw directly into the wooden or metal studs behind the board. These provide the best load capacity. If screwing into the studs is not possible (e.g., due to inaccurate stud placement), hollow cavity metal anchors (toggle bolts or snap toggles) are the optimal choice for medium loads. These open up behind the board and distribute the load over a large area.
RIROKE schrieb:
"Do you perhaps have specific recommendations for anchors that I can find at a hardware store..."
Almost all major hardware stores carry anchors from manufacturers like Fischer or Ramset. The "Fischer SX" anchors are universal anchors for brick walls, while for drywall, Fischer offers the "Metal" cavity anchor, which is sturdy and especially recommended for shelves.
So, for the brick wall I would use anchors like the Fischer SX8, and for the drywall, if direct screwing into the stud is not possible, use the Fischer Metal toggle anchors.
Good luck with your project!
