ᐅ Billy shelf high-quality materials for replacement parts.
Created on: 7 Jun 2021 09:23
Henningmar
Henningmar
7 Jun 2021 09:23
I plan to upgrade my Billy shelf with replacement parts and want to improve the quality of the materials used. I am especially interested in which materials are best suited for Billy shelf replacement parts, particularly for the load-bearing elements like shelves and side panels.
I wonder whether MDF, solid wood, or chipboard is the most durable and long-lasting choice. A combination of materials could also be considered. It is important to me that the shelf components remain stable, do not bend, and have the highest possible load-bearing capacity.
Does anyone have experience or expert knowledge about the best materials for these purposes? Are there any special tips regarding material selection that I should keep in mind, for example concerning moisture resistance or surface treatments?
Thanks in advance for your opinions and recommendations!
Jodyro
7 Jun 2021 10:45
For load-bearing components, I recommend plywood panels. They are stable, dimensionally stable, and better than MDF or particleboard.
Palenar
7 Jun 2021 14:38
Hello Henningmar,
Your question is very important to truly optimize the durability and safety of the Billy shelf. I would like to go into more detail here:
First of all, MDF (Medium-Density Fiberboard) is inexpensive and smooth, but it is rather unsuitable for load-bearing shelf parts because the material can swell under high loads and moisture. The shelves can bend, especially with longer spans without a central support.
Particleboard is similarly affordable but usually even more prone to sagging and moisture absorption. It performs significantly worse under long-term loads.
In my experience, plywood panels or high-quality multiplex boards made of several glued layers are best. The glued layers counteract each other’s warping, which greatly increases stability. Multiplex is usually more resistant to deformation as well.
Important with solid wood: It tends to warp and reacts to moisture. If it is unplaned or untreated, it can crack or swell.
The thickness of the boards is also crucial: For load-bearing shelves, at least 18 mm (0.7 inches), preferably 21 or 24 mm (0.8 or 1 inch), if the shelf will be heavily loaded.
Jodyro schrieb:
For load-bearing parts, I recommend multiplex panels.
I can only confirm that. Multiplex is not cheap but a worthwhile long-term investment.
Two more questions: How much weight per shelf surface is your shelf expected to carry? And what is the humidity level in your storage/living area?
Marlenepa
8 Jun 2021 08:17
Hello Henningmar,
to complement Palenar’s input, I would like to summarize the most important basics again. This is especially helpful when you are not familiar with technical terms.
MDF is a wood fiberboard made from very fine wood fibers bonded with synthetic resin. It has a smooth surface, is easy to paint, and relatively inexpensive, but it lacks strength under high loads.
Particleboard consists of coarse wood chips glued together. It is cheaper, but very susceptible to moisture.
Multiplex/plywood panels are made from several veneer layers that are glued crosswise. This creates a stable and durable material that is much less prone to movement than solid wood.
Solid wood is, of course, a very high-quality material, but as mentioned, it tends to expand and contract with changes in humidity.
In summary:
- For maximum stability, multiplex panels are the best
- If your budget is tight, thicker MDF panels with medium support are an option
- Make sure to have good surface sealing to keep moisture out
I hope this helps you with your decision. 🙂 If you like, I can also provide sources for multiplex panels.
pikin
9 Jun 2021 11:02
To add to the previous answers:
The choice of materials for replacement parts in the Billy shelf must meet two main criteria: load-bearing capacity and dimensional stability.
Under real load conditions, thin particleboard or MDF panels can sag even under moderate weight. Over time, edges and glued joints may come loose, especially with fluctuations in humidity.
Plywood panels (made from beech or birch) with a minimum thickness of 18 mm (0.7 inches) offer a very good balance of strength and weight. The veneer layers are glued in a way that distributes the load optimally.
An important recommendation: when making replacement shelves for Billy units, the edges should be additionally protected with a sturdy edge banding (e.g., ABS edge) to prevent swelling. Sealing with a water-repellent varnish is also advisable.
An alternative or complement could be coated MDF panels (melamine resin coated) if the budget does not allow for plywood. They offer somewhat better moisture resistance than raw MDF panels but are still not as strong.
Summary of my recommendation:
- Shelves: plywood 18-21 mm (0.7–0.8 inches), with edge and surface sealing
- Side panels: MDF or particleboard for light loads, or alternatively plywood or solid wood
If more precise load values are needed, I can provide tables and material data sheets.
Marlenepa schrieb:
Make sure to have a good surface seal
This is essential for durability, especially since shelves are often placed in varying environments.
Hope this helps!
