ᐅ Embedding / Casting Beam Ends in Concrete – Which Protective Insulation to Use
Created on: 8 Dec 2025 20:49
NoName77Hello forum!
Here is the situation: The ends of solid structural timber beams are going to be fully encased in masonry, and smaller existing gaps will be filled with concrete, cement, or similar materials. Since the wood itself must not come into direct contact with the masonry or plaster due to the risk of rot and moisture transfer, I would like to know if there are any methods to isolate the beam ends from the masonry.
For example, at the contact surfaces, could they be "wrapped" with something like a bitumen sheet (or a coconut fiber mat??) to prevent direct contact with the wall? I understand that a bitumen strip itself would not be suitable and is only mentioned as an example of the type of method I have in mind. Alternatively, is there a special mortar, concrete mix, or other material that would allow the wood-to-concrete/masonry connection without causing damage to the wood over time?
Many thanks in advance!
NoName77 schrieb:
The following situation: Beam ends made of structural solid wood are to be completely embedded in masonry, and smaller existing gaps are to be filled with concrete/cement, etc. Since the wood itself must not come into direct contact with the masonry or plaster material due to the risk of rot and moisture balance issues, I would like to know if there are any methods to insulate the beam ends from the masonry.
For example, at the contact surfaces, wrapping them with some kind of bitumen membrane (or coconut fiber mat???) to prevent direct contact with the masonry. I know the bitumen strip itself is not suitable; it’s just an example of the kind of method I mean. Or is there a special mortar, concrete mix, or other material that allows a wood-to-concrete/masonry connection without the wood being damaged sooner or later? I wouldn’t fully embed them in masonry at all. Why do you want or need to do that?
My suggestion: Place the beam ends on a masonry barrier membrane. Leave some air space around them and wrap with a vapor-permeable material (e.g., mineral wool) to allow some ventilation so the wood can "breathe." At the front, create a neat closure, for example with compressible sealing tape.
user-d29 schrieb:
My suggestion: place the beam ends on a masonry damp-proof membrane. Leave some air space around them and wrap them with vapor-permeable material (such as mineral wool) to allow ventilation and let the wood "breathe." At the front, create a clean finish using, for example, a compression sealing tape. From what I can see, the roof beams rest directly on the underside of the wall or the ring beam. I also read somewhere in a construction guide that this is now common practice because otherwise, the beams could be exposed to condensation permanently. Rising damp would probably no longer be an issue at this point.
The wall plates, which rest along their entire length on the external walls, are "open" on the sides and can therefore breathe; they are not plastered or wrapped in waterproof membranes, for example.
If the beam ends rest directly on the wall but are open on the sides—for instance, by using the mineral wool you mentioned—there shouldn’t be any problems, right? Air supply would then be ensured.
