I am currently exploring the idea of using IKEA Platsa furniture not just in the usual way, but specifically modifying or customizing it for DIY projects. I am wondering if there are more concrete and practical DIY projects that are tailored explicitly to the Platsa system.
I don’t mean general furniture upgrades, but creative and technically feasible concepts or building instructions that use the Platsa system as a base, for example for multifunctional furniture, smart storage solutions, or unusual combination possibilities.
Does anyone know of such projects, ideally with tips on materials, tools, or maybe sources of inspiration that relate specifically to this system?
Thanks in advance for your insights and advice!
plo32 schrieb:
Does anyone here know of such projects, ideally with tips on materials, tools, or possible sources of inspiration specifically related to this system?Platsa is well suited for modular wardrobe combinations. Doors or drawers can be replaced with wooden panels and upgraded with handle strips or sliding systems. Tools: cordless screwdriver, drill, possibly a router. Much of it is based on modifications of standard components.
plo32 schrieb:
Does anyone here know of projects like this, ideally with tips on materials, tools, or possible sources of inspiration specifically related to this system?The IKEA Platsa system is known for its high modularity, making it popular for various DIY projects. Common projects include:
- Installing cabinet lighting using LED strips, especially inside drawers and open compartments.
- Combining the units with custom-made countertops or shelves, for example, from solid wood or plywood.
- Converting units into benches or room dividers by adjusting cabinet height and adding cushions.
Regarding tools, in addition to standard equipment like cordless drills and drill bits, a jigsaw is recommended for cutting shelves.
Materials: wood glue, screws, and optionally plastic edging strips for finishing edges. When available, detailed instructions are usually found in DIY forums or crafting platforms that focus on modular building methods.
RAFAEL schrieb:
The IKEA Platsa system is characterized by its high modularity, making it interesting for various DIY projects.However, it remains a question how far one should intervene in this system. IKEA deliberately designed it for easy assembly and interchangeability.
Renegi schrieb:
You can replace doors or drawers with wooden elements and upgrade them with handle strips or sliding systems.This is an approach that certainly works well, but if you plan more extensive modifications, you should check the load-bearing capacity and connection mechanisms. A purely aesthetic modification is often not enough to truly expand the furniture’s functionality. I would be interested to know if anyone already has examples of successfully pushing these limits. Just to further explore the question from plo32.
ONRONA schrieb:
I’m curious if anyone knows of examples that have successfully pushed such boundaries.That’s my point: Many DIY projects are simply about changing the appearance or adding supplementary parts without altering the fundamental system. Although the Platsa system is modular, its design and choice of materials are primarily aimed at easy use rather than complex technical modifications.
Furthermore, it is important to critically consider whether these DIY extensions actually offer functional improvements or remain just gimmicks.
Referring back to the initial question from plo32 – “are there any specific DIY projects for Platsa” – a valid answer, in my view, would be that while there are numerous creative ideas involving surfaces, features like lighting, or shelves, there is little to nothing that truly changes or revolutionizes the system’s underlying structure.
Is there anyone who disagrees and can provide concrete projects that go beyond mere cosmetic enhancements with proof?
