ᐅ Are there specific screws designed for assembling the IKEA BRIMNES that fit better?
Created on: 25 Sep 2024 10:13
Waclawte68
Hello everyone, I am currently planning to assemble an IKEA Brimnes wardrobe and noticed while sorting the screws that some of the supplied screws do not fit well or tend to twist or get slightly damaged during assembly. Therefore, my question is: Are there any special screws or alternative materials for assembling the BRIMNES that are better sized, more durable, or specifically designed for this furniture series? I want to build the piece as stable and durable as possible without having weak points in the joints later on. Does anyone have experience with alternative screws for BRIMNES, for example in terms of metal quality, size, length, or thread thickness, that are particularly recommended for assembly? Many thanks for any tips or advice!
SETHBLA
25 Sep 2024 16:03
Are there special screws for assembling the IKEA Brimnes that fit better?
The answer is: Yes, instead of the supplied screws, I recommend coarse-threaded chipboard screws made of stainless steel or zinc-plated, with length and thickness as close as possible to the original screws.
This provides better grip and prevents stripping. Wooden dowels help if the holes are worn out.
Kinbu
25 Sep 2024 17:10
SETHBLA schrieb:
Instead of the supplied screws, I recommend coarse-threaded chipboard screws in stainless steel or zinc-plated, with length and diameter as close as possible to the original screw.
Exactly, I agree with that. Stainless steel is especially suitable for damp areas like bathrooms or kitchens; otherwise, zinc-plated screws are usually sufficient.
What was very important during my assembly of BRIMNES: never reuse an old, worn-out hole with a thinner screw, as it won’t hold securely for long. Thread-cutting drill bits for chipboard can also help reduce metal stress here.
blapau
26 Sep 2024 09:24
Regarding screw selection: The weight the BRIMNES is expected to support is an important factor when choosing the type of screws.
Clothing and closet furniture are subjected to significant pressure and tension forces, especially on the side panels and joint corners. Therefore, a firm driving torque is essential, which can be achieved with higher-quality particleboard screws.
Particleboard screws with larger heads also provide a more even grip on the panel surface without damaging the material.
If individual screws don’t fit, instead of forcing the next size, it’s better to choose screws that fit properly and, if in doubt, select the strongest ones that match the dimensions.
Dilen
26 Sep 2024 11:42
Waclawte68 schrieb:
I will test whether wooden dowels provide reinforcement and am still looking for recommended screw types for BRIMNES.
That strongly supports your idea. For the wooden dowel option, I would recommend carefully pre-drilling with an appropriate wood drill bit and purchasing dowels with an exact fit (e.g., 8 mm). This often holds better than screws alone.
Alternatively, plastic anchors or special furniture connectors can be helpful, depending on the location.
One more thing I’d like to know: Are you using a cordless screwdriver or working manually? That often affects how much torque can be applied without damaging materials.
Regarding the screws themselves: A good option is, for example, Spax wood screws designed specifically for furniture and wood-based panels. Many come with ETA certification for improved quality.
Palenar
27 Sep 2024 07:33
I would like to add some information on the topic of screws for BRIMNES, as there are several important details to consider.
First, the material and surface treatment of the screws should not be underestimated. Cheap screws with poor galvanization can start to rust after a short time, which negatively affects both durability and appearance.
Second, the screw length should always be chosen so that it does not go all the way through the panels but still provides sufficient grip in the wood. If the material seems too thin in some areas, additional angle brackets can sometimes be installed discreetly to improve stability.
Third, regarding assembly: pre-drilling holes when using replacement screws can sometimes help, especially when switching to harder metal screws. In this case, you could use a drill bit about 1–2 mm (0.04–0.08 inches) smaller than the screw shaft diameter.
I would advise against simply replacing screws if the holes are already significantly worn out; instead, it is better to use wall plugs or reinforcements before changing the screws.
If anyone is interested, feel free to share how different screws or methods have specifically helped with BRIMNES.
