ᐅ What tips or tricks are there for assembling the IKEA BRIMNES furniture?
Created on: 31 Mar 2021 08:17
Kenmin
Kenmin
31 Mar 2021 08:17
Hello everyone, I am currently assembling the IKEA Brimnes bedroom furniture set and encountering a few challenges that I assume others have experienced as well. Therefore, my question is: What practical tips and tricks are there to make the assembly of BRIMNES as smooth, quick, and safe as possible? I am especially looking for guidance on the optimal sequence of assembly, advice on handling the sometimes confusing instructions, and experiences on how to avoid mistakes in individual steps. I am also particularly interested in recommendations regarding tools, preparation, and how to make the often somewhat tricky fastening of the fittings more efficient. Thank you in advance for your feedback!
sanjon
31 Mar 2021 09:03
It is best to first sort and check all the parts. This helps to avoid searching for them later. For the fittings, I recommend screwing them in loosely at first and tightening them properly only at the end.
SUDAN
31 Mar 2021 09:43
A few tips from my experience:
- First, lay out all parts and tools in an organized way.
- Read the entire instruction manual before you start.
- Work section by section, not randomly.
- Use a cordless drill with adjustable torque to avoid damaging the wooden dowels.
- Always tighten screws at the end, but don’t do it too early.
Common mistakes include mixing up parts, such as the back panel, so it’s better to double-check if unsure. Also, driving screws in before the part is properly positioned can cause rework.
My summary: Be patient and don’t rush the screwing process.
RonJarrett
31 Mar 2021 10:07
Additional information: A critical point is the installation of the metal hinges on the doors. It helps to have pilot holes pre-drilled or at least lightly prepped with a small drill bit. This prevents the wood from splitting or the screws from being positioned at an angle.
Additionally, using a rubber mallet when inserting the wooden dowels is advisable to avoid damage.
Ryder35
31 Mar 2021 11:22
Always tighten all screws by hand first, just until everything is in place. Final tightening should be done at the end. This ensures everything fits together better.
Kenmin
31 Mar 2021 12:05
sanjon schrieb:
For the fittings, I recommend screwing them in loosely first and tightening them properly only at the end.
That makes sense. Have you encountered any situations where a different sequence should definitely be followed? And what tools do you specifically use for the screws— is a simple screwdriver sufficient, or do you recommend a cordless drill?
